Old 25-08-08, 05:17 PM   #1
monkey
Default Justi fitted a standard exhaust. Pipe sealed with silicone. How long before I start motor?
Just fitted my standard exhaust to my pointy and sealed the sleeve pipe with silicone. How long should I wait before I start the motor? I don't want to blow the silicone out but it's a good day to get things done.
Old 25-08-08, 05:23 PM   #2
Default Re: Justi fitted a standard exhaust. Pipe sealed with silicone. How long before I start motor?
it dont take long to dry, leave it half hour or so?
Old 25-08-08, 05:24 PM   #3
Dangerous Dave
What kind of silicone, was it proper gasket stuff, if so give it 15 mins for a good seal as long as it is just to check for air leaks.
Old 25-08-08, 05:28 PM   #4
monkey
I used bathroom type silicone. Meant to take 24 hours but it's such a thin layer in there.
Old 25-08-08, 05:29 PM   #5
not long at all.
Old 25-08-08, 06:56 PM   #6
monkey
Thanks fellas. It's gonna get longer to dry than I thought as I have to de-spike the alarm and possibly re-program the remotes. Bloody alarms.
Old 25-08-08, 08:30 PM   #7
TEC
TEC's Avatar
Originally Posted by teriyakimonkey View Post
I used bathroom type silicone.....
I'm probably wrong but aint that just stuff waterproof, not heat proof
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 25-08-08, 08:32 PM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
nope you spot on wont last long at all, use the oven silicone, or some of that instant gasket
05 DRZ400E
RIP hovis
Old 26-08-08, 05:14 PM   #9
Dangerous Dave
Correct, you may as well coat the joints in chocolate. Proper gasket silicone is the stuff to use.
Old 26-08-08, 07:08 PM   #10
monkey
Whoops! I'm sure someone on here told me it was fine to use. Says on care sheet it goes up to 140 degrees so I'll give it a run and see what happens. (When I've got road tax of course.)
exhaust Silicone/sealant anyone? Lucas Soho Massive 9 24-04-09 02:48 PM
Beaulieu motor museum in southampton... anyone been? and more importantly - how long does it take to get around it? Paul the 6th Idle Banter 10 23-01-09 11:39 PM
fitted alarm now won't start. stuballs SV Talk, Tuning & Tweaking 4 17-05-08 05:58 PM
Refitting standard pipe: link pipe? Jay1 SV Talk, Tuning & Tweaking 6 17-04-08 09:51 AM
Difficult cold start (and loose exhaust pipe) owennewo SV Talk, Tuning & Tweaking 10 18-11-05 07:01 PM
