Old 28-08-08, 05:41 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default regulating a circuit
i have a glow start that i use to run model engines and it is plugged into a control panel with a built in regulator that regulates it to 2V from a 12V gel cell so it wont blow the glow plug
basically i want to bin the control panel and just have a glow start with a long leed connected to a 12v gel cell, question is can i buy a small regulator that i could wire into the circuit?
i went into maplins on my way home from work to ask if they had anything and they acted like i was speaking alien, but then again thats pretty much the norm for them
help much appreciated tar
05 DRZ400E
RIP hovis
Old 28-08-08, 06:49 PM   #2
Baph
Default Re: regulating a circuit
You didn't specify what you want the output of the regulator to be, so...
12V regulator: http://www.usblogger.com/Electronics..._Regulator.htm
Look for the LM values, and write a few down.
2V regulator: UA78L02A. EDIT: yes, that was from memory.
Take those back to maplin and shout at them in a very clear voice "GET ME ONE OF THESE. IF YOU NEED HELP FINDING IT, CALL THE TECH SUPPORT NUMBER IN WOMBWELL!"
(I used to work in a Maplin store).
Old 28-08-08, 07:55 PM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
i've no idea baph im a noob, just want a 12v to 2v if that make sense?
05 DRZ400E
RIP hovis
Old 28-08-08, 07:58 PM   #4
You want a 2v regulator then, maybe a variable resistor would be better though in case you get a gummed up plug that needs a couple more volts. Try an RC forum as IIRC it's pretty common to build your own power panel.
Old 28-08-08, 08:09 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
i have got a number of power panels, just im sizing down my gear as i dont really do it much anymore
i've probably even got a 2v cel kicking about some were
05 DRZ400E
RIP hovis
Old 28-08-08, 08:13 PM   #6
3v works alright too, what about just buying a glow driver?
Old 28-08-08, 08:18 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
well the original plan was to hook it up to a lipo pack and strap them together, then if the lipo went flat and i didn't have my chargers i could plug it into a cel
05 DRZ400E
RIP hovis
Old 29-08-08, 03:47 PM   #8
Baph
From the above, it seems that a regulator with 5v output would be ideal, then a potentiometer to reduce this output. The problem there being getting the voltage right, but I'd just hack a cheap DMM into the console.
The staff in Maplin should be able to sort that out, but just in case, the number followed by a 'k' on a potentiometer is basically the higher the number, the more accurate it is.
Maplin stock code for a 5v regulator is LM323K (sometimes I wish I could forget those numbers ). That regulator is good for 3A.
Old 29-08-08, 04:27 PM   #9
Wideboy
Evel Knievel
Wideboy's Avatar
cheers baph, sounds like they shouldn't have let you go
05 DRZ400E
RIP hovis
Circuit Gearing chardy Mini-Twins 3 12-04-09 06:52 PM
Nearest Trackday Circuit... Biker_Billy Bikes - Talk & Issues 9 09-08-07 02:59 PM
Brands GP circuit Jdubya Track Days 2 12-06-07 02:52 PM
Crash.NET - Circuit-by-circuit with Dani Pedrosa. NewsBot News 0 04-04-07 04:10 PM
How do I check the charging circuit? thornton_chris SV Talk, Tuning & Tweaking 21 27-01-07 10:59 AM
