Old 28-08-08, 09:19 PM   #1
vardypeeps
Default Headlight help please
Evening everyone.
Having a bit of trouble with my head light lo-beams. I have a SV650s 99 (Curvy) and when the lights are on lo-beam they do not come on but when on hi-beam they both come on. I have bought new (expensive) bulbs for them but the same is still happening.
I checked the fuses and noticed that the fuse had blown and replaced with a spare that was in the case but as soon as I turned them on POP the fuse went.
At first I'm thinking it could just be dodgy fuses but is there anything else I should consider??? All the other electrics work absolutly fine
Thanks for your time in advance guy's n gal's
Old 29-08-08, 07:01 AM   #2
Dangerous Dave
Default Re: Headlight help please
Check around the headstock where all the cables run for damaged wires, common problem due to chaffing. If there is no sign there then have a look around subframe for the same, next common problem.
Old 29-08-08, 08:00 AM   #3
vardypeeps
Cheers D Dave I will have a bash at that one see if can source the problem. Anything else it might be?
New headlight(s) matt c Photos 4 22-10-08 10:44 AM
Headlight Stig Stuff Wanted 3 10-05-07 04:13 PM
headlight rxape Stuff Wanted 1 15-07-06 03:22 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
