Old 29-08-08, 09:59 AM   #1
Nicky S
Nicky S's Avatar
Default curvy chain and paddock stand
k well it has come to that gr8t time of me having to do my chain becuase it has become lose well very lose iv only had the bike 3 4 days so dnt know ever thing about it atm.
i was jsut woundering if someone could tell me how to do it and also if they know what the torque is for the back wheel.
it a 02 curzy.
also any one know were you can get a nice paddock stand so it easyer for me to get the bike off the ground . . . . ? and plz dnt say ebay
thanks :P
Nicky S is offline   Reply With Quote
Old 29-08-08, 10:02 AM   #2
Alpinestarhero
Default Re: curvy chain and paddock stand
The best stands (IMO) are Abba stands or the NWS stands (which are a similar thing). Instead of lifting the bike off the ground by the swingarm, they attach at the swingarm pivot point, and get the whole wheel off the ground like that
Means much better access and easier to work with, IMO.
I think the rear axle torque for the nut is 100 Nm, but dont take that as gospel.
Matt
Old 29-08-08, 10:23 AM   #3
Nicky S
Nicky S's Avatar
k so i got paddock stand bit done any one wanna sort of walk me throught how to do the chain
Old 29-08-08, 10:37 AM   #4
fizzwheel
fizzwheel's Avatar
You should adjust the chain tension on the side stand not on a paddock stand.
Procedure for doing the chain tension is in the owners manual if you have one.
Basically undo the wheel nut, then use an allen key to undo or do up ( depending on which way you want the back wheel to move ) the allen head bolts on the end of the swingarm. IIRC the chain tension should be 25mm - 35mm but there shoudl be a label on the swingarm the tells you what to set the tension to as I cant remember.
Old 29-08-08, 11:36 AM   #5
Nicky S
Nicky S's Avatar
thanks for that iv done it now just one small question thought is 47 right for the torque becuase to me that seems small ??
Old 29-08-08, 11:39 AM   #6
Alpinestarhero
Oh yea, dont trust the marks on the swingarm for wheel alignment - they are often not accurate. My dad told me to do a set turn on each allen key adjuster - one flat edge at a time
Old 29-08-08, 11:42 AM   #7
vardypeeps
For a curvy it's 65 for the rear axle in the good old haynes. Chain should be 25-35mm on the side stand and make sure it's lubed up!
Old 29-08-08, 11:46 AM   #8
Dangerous Dave
+ 1, there is no need for a main stand as it can be doen easily on the side stand.
Spot on there Fizz, and torque the spindle/axle back up to 65Nm and while you are at it don't forget to lube up the chain.
Old 29-08-08, 12:00 PM   #9
Nicky S
Nicky S's Avatar
yea that what my dad told me to
Old 29-08-08, 12:01 PM   #10
Nicky S
Nicky S's Avatar
right so haynes says 65 but the manual for the bike says 47 ummmmmmmm i think im gan go with haynes ....
chain adjustment on paddock stand skyline Bikes - Talk & Issues 3 14-03-09 07:02 PM
Adjusting the chain without a paddock stand? TheShadow Bikes - Talk & Issues 25 07-05-08 05:09 PM
Chain maintenance w/o paddock stand Baph Photos 14 26-02-07 01:44 AM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Do I need a paddock stand to adjust the chain? thor Bikes - Talk & Issues 16 10-04-06 08:10 AM
