Old 29-08-08, 01:06 PM   #1
shonadoll
Default Fitting an exhaust to a K7
apparently it has a lambda sensory thing I have to avoid? I ordered a Beowulf exhaust, and it looks pretty logical to put on, but it also looks like I can unbolt the original exhaust rather than cut through it?
I'm just worried in case I chop too much off - apparently the K7 is different from other models in this respect, does anyone know?
Old 29-08-08, 02:20 PM   #2
Dangerous Dave
Default Re: Fitting an exhaust to a K7
Nah... you have to cut it still as far as I am aware.
Old 29-08-08, 03:06 PM   #3
shonadoll
Ok, thanks.
Old 29-08-08, 04:24 PM   #4
shonadoll
Does anyone know about the lambda sensor thing?
Old 29-08-08, 04:29 PM   #5
Dangerous Dave
Keep it in.
Old 29-08-08, 06:34 PM   #6
gazza
The end can has to be cut off. I cut mine about 50mm towards the endcan from the weld line . The lambda sensor is left in position. It aint a hard job, took me about 20 mins start to finish. Just line up the new can and link pipe to get the approx point that the pipe needs to be cut.
Old 29-08-08, 07:17 PM   #7
shonadoll
Brilliant, thankyou so much, needed that detailed stuff.
Old 29-08-08, 07:18 PM   #8
shonadoll
Originally Posted by Dangerous Dave View Post
Keep it in.
Thanks!
Fitting A New Exhaust sid99 SV Talk, Tuning & Tweaking 28 03-10-08 07:17 PM
fitting exhaust sv650nutter149 Thames Valley 4 22-09-07 08:59 AM
Exhaust fitting Born again SV Talk, Tuning & Tweaking 3 19-04-07 02:47 PM
ART Exhaust (fitting) xlewdx Exhausts 8 17-12-06 07:06 PM
Fitting exhaust steveo Exhausts 6 27-02-05 08:02 PM
