Old 03-09-08, 03:40 PM   #1
Alpinestarhero
Default Heated grips not working
My oxford heated grips don't heat I can only think that the controller (the old analogue dial) has given up; the red L.E.D still comes on, indicating that there is power getting to it from the battery, but the grips dont get warm. I've checked the connections and given them a clean with electrical contact cleaner, but nothing.
So, what could I use as a suitable new switch, something with a variable resistor in it?
Matt
Old 03-09-08, 03:54 PM   #2
neio79
Default Re: Heated grips not working
Yes they will be a variable resisor controling the current, hence the heat. Should be simple enough to take out and replace.
Old 03-09-08, 04:30 PM   #3
Baph
It is indeed that simple, however, there's half a tonne of epoxy resin inside the damn thing!!
Option 1: Acidic epoxy solution to clean the epoxy off, diagnose & replace the potentiometer. Reseal with epoxy.
Option 2: Visit Maplin, get a small plastic box, a potentiometer, a 12v LED, a little wire, and solder yourself a new controller.
Option 3: Ebay for a cheap controller. Or talk to Hovis, he's likely to have a spare controller kicking around from last year.
Old 03-09-08, 06:11 PM   #4
Alpinestarhero
Cheers baph, I'll ask hovis, but I'll probably end up making a new, water-tight, smaller controller.
Be prepared for numpty electronics questions
Old 03-09-08, 06:32 PM   #5
Grinch
You can test the grips by unplugging the controller and then plugging one of them direct into the control power supply. You get the full 12v to the grip and it should heat up lovely.
My analogue one failed and I had it replaced with the digital one and its rubbish. So at some point I'm going to Maplin to make my own.
Old 03-09-08, 07:17 PM   #6
thinone
Matt
how did you find out they weren't working - was it frosty this morning?
Old 03-09-08, 07:20 PM   #7
hovis
sorry.................. stupidly i left it on the bike
been looking on eblah, and the whole set up goes for about £35
Old 03-09-08, 07:27 PM   #8
Alpinestarhero
cold wind down here on the coast, then it rained....
Old 03-09-08, 07:28 PM   #9
neio79
And his fanny hurt
Old 04-09-08, 06:46 AM   #10
STRAMASHER
STRAMASHER's Avatar
My left hand heated grip has given up the ghost. Last time I just got a new controller and evrything was fine and dandy for a year or so. Always the same bloody side.
I have the Oxford analogue one also. Why is the new digi one so poor compared to the old one?
Heated Grips? smidge26 Riding Gear 41 09-11-08 01:06 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
Oxford heated grips not working. thor Bikes - Talk & Issues 11 10-04-06 09:12 PM
Heated Grips NAPA121 Bikes - Talk & Issues 7 12-09-05 09:38 PM
Heated grips no longer working dclifford Bikes - Talk & Issues 6 04-09-05 09:37 PM
