Old 06-09-08, 05:22 PM   #1
bomber1973
Default Headlight lameness / confusion
I've got a '99 UK SV650S and the headlights are, well, crap.
Each side as a 45/55W H4 bulb in but only one element is actually powered - only two wires to each bulb. When in dip mode only the left light is lit up and in high beam the right hand one comes on as well. According to all the wiring diagrams i've seen both lights are wired in parallel AND switching between dip and main should switch between them, not just adding in the high beam on top of the dip?
Anyone got any clues or describe how there lights behave?
cheers
Old 06-09-08, 05:30 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Headlight lameness / confusion
On my UK y2k SV650S both sides come on at the same time for both hi and lo beam.
Are you sure it's a UK bike and not a parallel import?
If it is just two wires to each bulb then you can either re-wire it or get the front sub-loom and replace it[1].
Druid
[1] Although this is a bit of a PITA.
Old 06-09-08, 05:52 PM   #3
dirtydog
Knob faced knobster
dirtydog's Avatar
Sounds like you've got a euro spec bike
edit: have you actually checked that both bulbs are working ok? As i don't think the euro spec ones use H4 type bulbs
2011 Speed Triple 1050
Old 06-09-08, 06:12 PM   #4
bomber1973
Druid
Cheers mate. Pretty sure the bikes not a parallel - all the paper work ties up ok. Just done a bit of loom chasing and it does just seem to be the front instrument/lights loom that is weired - the wires which disapear into the chassis harness for the dip light fuse comes from the lighting switch (W/Y) rather than the dip switch (Y). Think I'll be modding this loom as everything else looks fine. Still a mystery why though.
Explains why the lights were **** though, I was starting to think it was just me being an old git....
Old 06-09-08, 06:17 PM   #5
Dave20046
Dave20046's Avatar
I think you've misunderstood bomber, I took it to mean each bulb (both lit) have two elements or fillaments in but bomber's only noticed 1 is lit.
Sorry I have no advice on the subject I'm a newb
Old 06-09-08, 06:45 PM   #6
fastdruid
fastdruid's Avatar
First thing though is to swap for 55/60's, that's 10w of extra light even with one bulb for a start.
Druid
Old 06-09-08, 08:05 PM   #7
Dave20046
Dave20046's Avatar
Druid
fastdruid out of interest are you actually a druid?
Old 06-09-08, 10:02 PM   #8
fastdruid
fastdruid's Avatar
No, it's a nickname I picked up at uni based on a misspelling of my first name. Fastdruid is just because I started to find other people had created logins as 'druid' and after trying a few combinations came up with that as something that was reasonable unique.
Druid
Old 07-09-08, 10:21 AM   #9
Dave20046
Dave20046's Avatar
Druid
Ah fair play, just wondered. Had a bit of trouble with the druids round these parts..
Colour confusion! gavinsky23 SV Talk, Tuning & Tweaking 6 07-02-08 11:40 PM
Insurance confusion DanAbnormal Bikes - Talk & Issues 7 25-09-07 07:43 PM
Continental confusion… Aurora Idle Banter 8 03-06-06 01:18 AM
Snorkel? Confusion... JakeRS SV Talk, Tuning & Tweaking 3 10-11-05 07:43 PM
Just to clarifymy confusion! 454697819 SV Talk, Tuning & Tweaking 8 21-04-05 06:51 PM
