Old 06-09-08, 08:27 PM   #1
mattb200
Default IT help please...How do I transfer from Access to......
Ok here's the scenario for all you IT professionals out there:
I have created a database in MS Access at work and need to be able to create a pre-filled MS Word doc from the data in the database. I have used a fair bit of VB code behind the custom forms and whilst I don't do this for a living I can usually create enough code to get around most issues and know some basic SQL.
What my database basically does is let the user log a 'query' and then provide a reference number. At this point I want the user to be able to click the OK button and automatically open a word doc with most fields pre-filled so that they only need to add an address to the letter and then print - which will not be stored in the db as it could be one of thousands of different addresses.
Had a bit of a play with the mail merge in Word but I think I am probably making it more difficult than it really is and just don't know how to do it.
Any suggestions on how to go about this would be appreciated.
Thanks
Synchronising with MS Access andyb Idle Banter 17 30-04-08 08:08 PM
Anyone got or have access to... zedleppelin1981 Soho Massive 0 01-10-07 02:54 PM
direct access Dave The Rave Pennine Massive 30 20-05-06 06:58 PM
Business transfer agents Ed Idle Banter 0 08-03-06 10:58 PM
