I have aftermarket small indicators fitted to my 2002 curvy s. They were fitted before I bought it. They flash really quick and not like normal indicators. Anyone know how I make them flash normally?
Knob faced knobster
Are they LED indicators?
2011 Speed Triple 1050 |
Either they're LEDs, or the bulbs are less than 21W.
You need to consume more power in the circuit to slow them down. This can be done by either adding a resistor, or changing the bulbs to the right ones for the SV. It's been covered many many times for LED indicators, so start with a search there & post if you get stuck. |
motrax do a variable relay this sorts the problem, i had the same on my thou so i sold em and put standard ones back on.
#5 | |
If only one, a bulb has blown or ( more likely ) bad connection. Tap it & see if it works then. |
will it solve the problem if i put origional ones on?
Knob faced knobster
It should solve it if you put the originals on
Not the normal type of indicator flash rate problem.... | DarrenSV650S | SV Talk, Tuning & Tweaking | 11 | 03-07-08 06:42 PM |
Indicator Problem | Side MS | SV Talk, Tuning & Tweaking | 23 | 26-05-08 07:11 PM |
Indicator Problem & fitting front fork seals | dannyboy81 | SV Talk, Tuning & Tweaking | 4 | 23-05-08 09:03 PM |
Indicator Problem & fitting front fork seals | dannyboy81 | Bikes - Talk & Issues | 0 | 19-05-08 08:44 PM |
Mystery indicator problem | sgorio | SV Talk, Tuning & Tweaking | 0 | 30-07-06 09:45 AM |
