Old 08-09-08, 12:20 AM   #1
Faisal
Default dodgy horn.
so...my horn is misbehaving...
sometimes it works fine and sometimes not at all...
the wierd thing is if it's not working, often stopping the bike and re-doing the immobiliser thing and restarting it will make the horn work again, but that doesnt always work...
any ideas what could be causing the problem?
tempted to check the wiring from the button to the horn but is there any chance the immobiliser could be causing the problem?
Old 08-09-08, 12:22 AM   #2
BBadger
Default Re: dodgy horn...
Wiring straight off.
If theres no problem on the external wires cheack the switch gear.
I wouldnt worry.. no one pays attention to my horn when they cut me up or at least till they get a mirror crushed!
Old 08-09-08, 06:59 AM   #3
Kilted Ginger
no personal experience but pretty sure I've read on here that there is a generec overheating problem, ie the heat of the engine caused the horn to fail but works ok once it cools down. Hth.
Old 08-09-08, 07:14 AM   #4
Alpinestarhero
My horn is excellent, its a comedy prop in its own right. I'll press the horn, sometimes it'll make the sound it was ment to, the other times it'll sound like its dying, then regaining conciousness, then dying. Its great, I think I'll have to get a sound clip of it sometime.
As far as I'm aware, its to do with the heat. It has got a little better (more normal) since I cleaned the connections a bit, but still provides excellent audio entertainment
Soulkiss's horn wins hands down though for effect. AR08 was a good example; I started the beeping, everyone else beeped their equally pathetic sounding standard horns, then Soulkiss let rip with his. Ah, memories..
Old 08-09-08, 08:34 AM   #5
Nobbylad
Nobbylad's Avatar
The horn on my K8 would stop working after about 20 mins riding....the general advice is that it's too close to the radiator and the heat makes the internals expand and stop it from working.
There are 2 solutions -
- bend the horn further away from the rad, or mount it somewhere else
- spend £20 on a Stebel Nautilus air horn from Halfords, take 30 mins to wire it up (there are some schemas on the .org just do a search for them), sit back safely in the knowledge that if you ever do need to use the horn, people WILL hear it (although not necessarily realise it's you....they'll be looking around for an artic, it's that loud).
Old 08-09-08, 01:27 PM   #6
Faisal
ok...so i went and bent the horn away from the engine...
hopefully that will keep it cooler...
will see if that does the trick!
Old 08-09-08, 01:32 PM   #7
breakz187
Any guides anywhere to rigging up a Nautilus?
I've just reserved one at halfords. The youtube videos are pretty good at demonstrating the volume of that thing
Old 08-09-08, 02:53 PM   #8
xXBADGERXx
Scurries off to Youtube as the Dog is near the speakers yet again ..........
Old 08-09-08, 04:10 PM   #9
Nobbylad
Nobbylad's Avatar
Check out this thread => http://forums.sv650.org/showthread.p...+schema&page=1
Page 3 has the schema for the wiring.
Old 08-09-08, 05:54 PM   #10
independentphoto
Check out HERE..... http://forums.sv650.org/showthread.p...light=nautilus
HTH
Garry
is this dodgy? hovis Idle Banter 34 17-02-08 11:29 PM
does this look dodgy to you? Paul the 6th Bikes - Talk & Issues 4 15-01-08 10:01 PM
Is this dodgy? plowsie Idle Banter 42 13-12-07 10:39 AM
How Dodgy Are You....? Scoobs Idle Banter 82 01-04-06 12:35 PM
Now this one is dodgy... Mike1234 SV Talk, Tuning & Tweaking 14 04-01-06 09:51 AM
