Old 08-09-08, 10:49 PM   #1
ljharmitt
Default Longest lasting?
What are the longest lasting chain and sprockets? Don't want to be spending too much, also dont mind if its standard gearing or not?
Any experiences? Also recommend me a good set of front brake pads
Old 08-09-08, 10:51 PM   #2
instigator
Default Re: Longest lasting?
X-Ring for a start, and the life of your chain and sprockets will probably be doubled near enough if you get a scottoiler or similar automatic lubing device. DID, Tsubaki...steel sprockets.
Brake pads - Can't recommend any, I just get standard EBC Organic numbers and use the engine for the rest of the braking requirements. :P
Old 08-09-08, 10:52 PM   #3
Luckypants
Luckypants's Avatar
If you want long chain / sprocket life then get a scottoiler. They really do work and extend chain life massively. My c/s currently on 16K and have not needed to be adjusted yet even. Constant lubrication is the key to long life.
Luckypants is online now   Reply With Quote
Old 08-09-08, 11:44 PM   #4
xXBADGERXx
I bought a DID X ring chain and JT Carbon Steel Sprockets from B and C express , fitted them myself and along with the Scottoiler I haven`t adjusted it once and that was 3 months ago . I do around 600 miles a month , maybe more in warmer weather and the Scottoiler is the key to long life as others have stated .
Old 09-09-08, 12:01 AM   #5
Lozzo
DID ZVM grade chain with steel sprockets and a scottoiler.
Old 28-09-08, 11:58 AM   #6
ljharmitt
What about the pads? Any recommendations and where to buy from? Don't want to spend over £50 for both left andd right
Old 28-09-08, 03:04 PM   #7
OEM aren't bad
Old 28-09-08, 04:19 PM   #8
Dangerous Dave
OEM aren't bad
+ 1
EBC HH pads
Old 28-09-08, 05:19 PM   #9
It's more to do with the owner than the parts tbh, any chain with steel sprockets will last well if well cared for or badly if not at the end of the day.
Old 29-09-08, 03:04 AM   #10
RandyO
I always had best luck, cost per mile with oem suzuki sprockets and DID o-ring chain
with a scottoiler, and zero maintenance on my part, I averaged 35,000 per set, front sprocket would always be the first to wear
What's the longest you've gone without.... Baph Idle Banter 55 23-03-07 10:36 PM
Who has the longest commute? Ward8124 Idle Banter 49 23-03-07 11:32 AM
WARNING - Scottoiler contents lasting FOREVER independentphoto SV Talk, Tuning & Tweaking 5 15-02-06 10:48 AM
The Longest Wait! DanDare Idle Banter 18 07-02-06 12:09 PM
Longest trip in a day Supadan Bikes - Talk & Issues 22 01-09-05 10:26 AM
