Old 09-09-08, 11:07 AM   #1
rob13
Default Laptop DVD problems - help!
Im trying to get a DVD to play on my laptop however, i've noticed that its not picking up the presence of a DVD in there. It works fine with CDs but DVDs wont work. Checking the region, its set on region 1 but when I try change it to R2, it wont let me. Theres 4 changes left, theres an R2 disc in the drive and I am the administrator. Anyone else had such a problem? Its bugging me!
Old 09-09-08, 11:13 AM   #2
simesb
Default Re: Laptop DVD problems - help!
Are you sure it's a DVD drive? Bit sucky egg, but if it don't say DVD on the front it may not be.
Are these commercial DVDs or home burnt? I know my old Tecra doesn't always recognise DVD+Rs.
Old 09-09-08, 11:26 AM   #3
Sosha
DVD Show up in File manager?
RegionKiller or something similar might be your friend....
Can't remember the name of the thing I use which is totally useless.
The fact I can't remember, not the thing I use obviously.
Old 09-09-08, 11:36 AM   #4
Woz
Might be an idea to upgrade the firmware. Mine wouldn't entertain discs but once i upgraded it, there were no problems at all.
Old 09-09-08, 11:39 AM   #5
rob13
Yeah its a proper DVD, no copy or anything like that. Im trying to update the driver but there doesnt appear to be any newer version.
Old 09-09-08, 11:43 AM   #6
Woz
It's not necessarily the driver you're after. Go to the manufacturers site and look for a firmware upgrade. You'll find your current version number in the device manager.
Old 09-09-08, 11:46 AM   #7
gettin2dizzy
Old laptop? They burn out so quickly I'm afraid. Try updating the firmware as suggested, and try reading other DVDs. It may just be buggered
Old 09-09-08, 12:04 PM   #8
Baph
The man is spot on.
I've seen issues in the past where the firmware somehow gets corrupt, and as a result, the opto sensor doesn't "fire up," effectively meaning that it assumes no CD/DVD present.
Updating the firmware, even if the current version is the latest is usually the best fix for the issue.
Old 09-09-08, 12:55 PM   #9
rob13
Cant even find the firmware. Have tried the Samsung site and its not on there.
IBM X32 Laptop FS TSM Idle Banter 1 20-03-10 10:20 PM
Laptop problems... missyburd Idle Banter 21 16-01-08 12:12 AM
Anyone need a laptop Iansv The Essex Lounge 7 24-09-07 11:50 AM
1Gb Laptop memory snoopy Idle Banter 0 24-06-06 04:20 PM
How much is this laptop worth? 21QUEST Idle Banter 1 20-06-06 10:16 AM
