Old 10-09-08, 09:09 PM   #1
stevie
Question Operating temperature for SV650 Sport (K8)
Hi all,
I took delivery of my new sv sport on Friday. One thing I have noticed is that the bike runs slightly hotter (high 80's to low/mid 90's degrees C ,and the fan cut in at 104 degrees c in slow traffic, although the temp dropped back to mid 90's when I was on the move again.) than my old K3 sv650s(high 70's to mid 80's). Can anyone tell me if this is normal for a K8?
It also has twin spark plugs on each cylinder,and a sensor in the exhaust pipe just after the front and rear pipes join.
Old 10-09-08, 09:16 PM   #2
xXBADGERXx
Default Re: Operating temperature for SV650 Sport (K8)
My K3 runs between mid 80 to 90 on the commute to work and fan cuts in on hot days when stood in traffic and heading for 100 , seems normal to me . It may cool down by a few more degrees when the bike is run in and not so tight . Either that or you and me both have a problem LOL
Old 10-09-08, 09:18 PM   #3
orose
Not sure about the K8, but my K6 generally hangs around the same sort of figures - 87 seems to be the temp it settles to. Did your old one have lowers on?
Old 10-09-08, 09:18 PM   #4
fizzwheel
fizzwheel's Avatar
Depends, traffic, road conditions, ambient temperature etc etc.
Yours sounds about right. I wouldnt be worrying about it if I was you.
Old 10-09-08, 09:20 PM   #5
stevie
Question Re: Operating temperature for SV650 Sport (K8)
Thanks for the replies, I feel better now. Also my K3 didn't have lowers. Here's hoping for a dry weekend to put some miles on the clock.
P.S So far I've fitted a fenda extenda and a Pyramid hugger in black, and I have a set of R&G crash bungs on order and the bike's colour is the metallic grey.
Old 10-09-08, 09:21 PM   #6
xXBADGERXx
Well if it does rain at least the gauge will drop a bit
Old 10-09-08, 10:33 PM   #7
Toby
I hope you haven't got a problem with temp, cause if you do, so do I! Mine seems to run between 80-90 normally.
Old 10-09-08, 10:36 PM   #8
jaffacakes
+1 Don't think you have anything to worry about
Old 10-09-08, 11:17 PM   #9
Paul the 6th
Paul the 6th's Avatar
mine seems to be about 90 ish on average
Old 10-09-08, 11:17 PM   #10
Paul the 6th
k5 with lowers btw
Trading sv650 for sv650 sport?? Wycombe Dave Bikes - Talk & Issues 12 24-08-08 10:26 PM
SV650S 2003 Operating Temperature? Pete SV Talk, Tuning & Tweaking 6 06-08-08 01:21 PM
max operating temperature richbeales SV Talk, Tuning & Tweaking 9 23-04-07 03:28 PM
Sv650 Sport The Basket SV Talk, Tuning & Tweaking 11 03-10-06 09:37 PM
Normal Operating Temperature azura SV Talk, Tuning & Tweaking 8 06-09-06 11:38 AM
