Old 15-09-08, 09:52 AM   #1
drag
Default Do i need a rejet, or is this something different ..
Recently fitted a new engine, tis running quite nicely, bar a little whizz/ rattle fromthe front end, it's prob the cam chain tentioner...but thats something to do another day.
I've noticed two main things that concern me.
1) In 2nd gear around 4K - 5.5K Rpm we've got no power, or the power we have in terribly lumpy, to the point where the bike is actually rocking forwards and backwards.
2) When we finally get up a bit of speed, say to the 100Mph mark, and above it's rather difficult to maintain a steady constant speed, now im aware of the engine braking on the SV's but surly it shouldnt be that strong around the 100mph mark, the best description i can give is that it feel like i have to constantly apply more throttle to maintain a constant speed.
I've a K n N filter in there, with standard jets, and a CCC Can the carbs were balanced recently. but again she's never been rejetted.
Old 15-09-08, 11:33 AM   #2
Dangerous Dave
Default Re: Do i need a rejet, or is this something different ..
A rejet should help, is the engine standard internally?
Old 15-09-08, 11:36 AM   #3
drag
Yes Dave it's standard internally ...altho i would like to put a set of cams in her, that can wait ..
I can understand the jetting sorting out the flat spot in 2nd, but does it explain the constant deceleration ?
Old 15-09-08, 11:46 AM   #4
petevtwin650
Obvious thing that causes drag is brakes. Get up to speed and pull the clutch in and see if the deceleration is the same.
Old 15-09-08, 11:49 AM   #5
drag
Good suggestion pete !! never though of that one.
I'd kinda ruled out the brakes as she seem pretty good down the low end, 40 - 70 mph ..but there again it's hard to say
Old 15-09-08, 12:42 PM   #6
I'd be suspecting fitment tbh... What you're describing sounds pretty lean-ey but your mods shouldn't cause it to be that bad, so I'm thinking maybe you have an air leak somewhere. Just using the usual "check the obvious" and thinking of things that were changed in the engine swap first.
Old 15-09-08, 01:01 PM   #7
drag
An air leak .... some where around the carbs .... now i assume a dyno run would be able to highlight this if that was the case ?
And even tho im running a standard enough kit, i'll be adding tank spacers soon enough, and mayb change over to a bmc filter, it's prob worth my while gettn it rejetted.
Old 15-09-08, 05:38 PM   #8
no point dyno'ing it, just visially check the carb clamps are tight etc etc.
If you fit any other filter you need to rejet after.
Old 15-09-08, 06:40 PM   #9
Airwolf
i had the same prob, when i fitted some rejetted carbs. i did not lift the tank at first.
the same feeling at 100 mph that something was holding it back.
lift the tank and the bike was set free, the engine rev'ed free. no more holding back at 100, just keeps going,
Old 15-09-08, 08:58 PM   #10
drag
Perhaps when they re fitted the carbs + engine they blocked the air flow some how ... i'll investigate this weekend so
Will I need to rejet? BoltonSte SV Talk, Tuning & Tweaking 23 15-04-08 09:22 AM
Rejet after Pipe install? SloppyJoseph SV Talk, Tuning & Tweaking 2 05-04-07 01:34 PM
K&N + Race can = Rejet? Blue_SV650S SV Talk, Tuning & Tweaking 13 27-07-06 06:23 PM
yoshi RS-3 on do i have to rejet raven22 SV Talk, Tuning & Tweaking 7 17-02-06 07:03 PM
Do i have to rejet or shim raven22 Exhausts 4 10-02-06 12:47 AM
