Old 16-09-08, 08:18 AM   #1
plowsie
Default Stubbied a can
Now she smells like an old car. Lean or rich?
How can I get the definative answer?
Old 16-09-08, 08:21 AM   #2
Dappa D
Default Re: Stubbied a can
hey plowsie cant answer your question fella but would be interested in seeing pics of your latest creation!!??
Old 16-09-08, 08:23 AM   #3
plowsie
Pics to follow later mate Its a pretty gash job, its not the can i think i will be using anyway, was just a, i'll see if i can do this before I feck up a perfectly good exhaust.
Old 16-09-08, 08:35 AM   #4
Dappa D
yea good work that makes sense!!!
Old 16-09-08, 08:44 AM   #5
dirtydog
Knob faced knobster
dirtydog's Avatar
Its a pretty gash job.
Why what's wrong with it?
2011 Speed Triple 1050
Old 16-09-08, 08:59 AM   #6
Probably lean, but check nothings blocked inside can
Old 16-09-08, 10:13 AM   #7
plowsie
It's just a bit of a scabby cut, tried to file it down as good as poss, the packing was screwed before i got to it so its not too clever.
Can I get it put on a dyno to check for rich or lean-ness?
Old 16-09-08, 11:30 AM   #8
sottondan
proberly lean however if you have a nice stretch of roasd near by you could try a plug chop not 100% accurate but gives good indication thats how i set my dynojet kit up and all i needed was to lift needle one clip
Old 16-09-08, 12:54 PM   #9
plowsie
Plug chop, is that where you pin the throttle to full and then hit the kill switch?
Old 16-09-08, 01:03 PM   #10
Stig
If you can smell petrol out the exhaust, it's running rich. If not, it's not.
Considering what you have just done to the can, I would not be suprised if what you can smell is the burning of all the loose packing which you would have disturbed.
Do you get an 'smoke' at all coming from the exhaust when revving the engine? If it has a faint brown hew, it's an idication the bike 'could' be running lean. But you would have had that before the exhaust was chopped as well. It's not very likely a stubbied can will make the bike run lean. This is down to fuel/air mixture ratio.
Stubbied my exhaust today. paiste SV Talk, Tuning & Tweaking 25 06-04-09 07:32 AM
Akrapovic stubbied Lozzo Photos 27 29-04-08 07:45 AM
getting my can stubbied how long shall i make it jans1971 Bikes - Talk & Issues 4 22-04-08 05:12 AM
Stubbied Akrapovic Lozzo Photos 19 12-04-08 10:15 PM
Stubbied Art Carbon Fibre slip-on Stormspiel For Sale - SV's and SV related items 25 08-02-08 11:27 AM
