Old 24-09-08, 12:57 PM   #1
Nobbylad
Nobbylad's Avatar
Default 4,000 mile service
How much do you reckon it's gonna cost me at a dealers?
Also, what bits should they deffo be replacing etc? (am in work, so can't look at my manual)
Any tips for things I should check when I pick it up too (apart from brakes/tyres/oil/fluids etc).
Not saying they'll make a mistake, but it's easy enough to forget to put something back in/on.
Thanks in advance!
Old 24-09-08, 01:18 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: 4,000 mile service
From memory its about £130 ish (was 2 years ago)
Unless you are wanting the dealer stamp then do it yourself - again from memory its Oil and Filter change and a good check over that nothing is loose, Oil and Filter should be about £35 (and thats using the best Castrol stuff that Halfords sell)
Check the Haynes manual for the full schedule of work.
Just did the 1st (4k) service on my Z750 myself - I figure that the money I save servicing will pay for anything that goes wrong if they refuse a warranty issue based on not having a stamp in the book.
Old 24-09-08, 07:58 PM   #3
Nobbylad
Nobbylad's Avatar
Finance co. dictates I have to have service stamp/warranty
Thanks
Old 24-09-08, 10:49 PM   #4
Paul the 6th
Paul the 6th's Avatar
no worries @ service thing.
I changed the oil & filter myself a few weeks ago - easy enough checked most of the nuts and bolts for any corrosion or "strange characteristics"... erm, yc showed me how to fit new ebc HH pads, well worth the money , checked tyres, back one is as square as a door frame = new tyres soon, had a chat with yc about suspension - gonna uprate it at some point and its all in good order for now. Think the 4k service is mainly to sort out the usual stuff and check everything is fine sounds like 16k is the biggie
Old 24-09-08, 10:54 PM   #5
Yes the 15/16k one is the expensive one, it requires the valve clearance check which if it has tightened up is quite involved to change.
Old 25-09-08, 08:06 AM   #6
Paul the 6th
oh and the air filter needs checking too. I asked padgetts suzuki if I'd need a new filter at 4k miles, the guy said not really but give it a check. Unbolted the petrol tank and unscrewed the 6 screws holding the airbox down = perfectly fine, gave it a quick suck off with the vacuum cleaner to get rid of any dust or owt
Old 30-09-08, 09:10 AM   #7
Nobbylad
Nobbylad's Avatar
Had the 4k service yesterday £111 which isn't bad I guess. OK the parts only cost around £15-20, but they checked a few things I wasn't sure about (incl. the Scottoiler that I fitted) and spent around 2hrs on it.
Old 30-09-08, 09:16 AM   #8
Paul the 6th
not bad really
7,500 Mile Service....... SoulKiss SV Talk, Tuning & Tweaking 9 15-06-07 06:13 PM
20,000 mile service £110 hovis Bikes - Talk & Issues 12 11-06-07 01:58 PM
15,000 mile service peanut SV Talk, Tuning & Tweaking 11 06-06-07 06:33 PM
15K mile service RAGAR SV Talk, Tuning & Tweaking 2 08-08-06 08:06 PM
8,000 mile service 22 SV Talk, Tuning & Tweaking 1 04-06-05 03:53 PM
