Old 25-09-08, 08:48 AM   #1
ricky
Default low rev misfire??
right
not sure on this one and what could be the problem
for a while now the bike at low revs feels as if its kangerowing down the road while to choke is only on half way.
but for the last week i noticed while on the motorway that with the choke off while at low revs ie 4k and when i go to speed up the bike splutters then power comes back!!
btw the bikes a curvey 2001
any ideas??
Old 25-09-08, 08:52 AM   #2
Dangerous Dave
Default Re: low rev misfire??
Was it cold, or a cold wind flow? Could be Carb Icing which is easily treated.
Old 25-09-08, 09:20 AM   #3
ricky
no not when its cold mate
this is after a good half hours ride as well and also does it on my way home when i leave work at 3pm
Old 25-09-08, 09:31 AM   #4
silent11
bad tank of petrol?
http://i35.photobucket.com/albums/d185/phild11/4sig.jpg
SEXY SV650S Full Faired K6 lots of mods to come
silent11 is offline   Reply With Quote
Old 25-09-08, 09:37 AM   #5
ricky
Originally Posted by silent11 View Post
bad tank of petrol?
i was thining this but its the 4th tank now in two weeks
think im going to have to strip the bike down a little and check things like fuel pipes etc etc
also was the curvey fitted with heated carps?? just something to rule out?
Old 25-09-08, 06:13 PM   #6
Davido
Misfire = check plugs.
Might not be the problem but a new set is F.A and won't do any harm to change. Plus it'll rule out one thing if it doesn't solve it.
(when you replace the front one, put grease around the lead to prevent the water from getting to it)
Old 25-09-08, 06:19 PM   #7
fizzwheel
fizzwheel's Avatar
Sounds like possibly a fueling issue. I had rough running on my curvey and I found that the choke plungers got stuck so the choke was on even with the lever in the off position so you might be suffering the same issue...
Misfire? Phaelok Bikes - Talk & Issues 6 01-11-08 08:04 PM
Misfire donscarecrow SV Talk, Tuning & Tweaking 4 25-08-08 09:48 PM
Still Got A Misfire SAMMY650 SV Talk, Tuning & Tweaking 8 08-10-07 07:34 PM
Misfire perhaps? Larry SV Talk, Tuning & Tweaking 2 02-09-07 10:31 PM
MISFIRE DAX SV Talk, Tuning & Tweaking 5 18-05-06 10:19 AM
