Old 28-09-08, 07:56 PM   #1
defiant
Unhappy Oil leak
Hi,
Just back from a 200 mile spin and have developed quite a bad oil leak
Took 0.7 of a litre to fill her up.
Can't tell where it's coming from though. There is oil smeared from the level indicator down and on the exhaust and bottom of the engine.
Anyone had a similar problem or have any ideas?
Any help greatly appreciated...
Old 28-09-08, 08:02 PM   #2
sv650k4
Default Re: Oil leak
Check all bolts etc...are all tight! i had a slight oil leak found it 2 be the hose that gose from the airbox 2 the engine had a slight split in it where it gose onto the engine and plus the we clip on it wasnt very good so changed it and cut the bit of the hose that had the split and it now seems 2 be 100% touch wood.
Old 28-09-08, 08:10 PM   #3
Degrease engine, dust it with talc. Will show you where it's coming from.
engine breathers are likely culprit if you've had it in bits recently, so is clutch cover.
Old 28-09-08, 09:05 PM   #4
defiant
Thanks lads.
I'll give it a clean and tighten everything up tomorrow..
Old 28-09-08, 09:07 PM   #5
Whoa. Just tightening clutch cover bolts will worsen the matter. It's plastic and overtightening will warp it.
Old 28-09-08, 09:15 PM   #6
defiant
Should have said check tightness of bolts...
Old 29-09-08, 06:52 AM   #7
Dangerous Dave
Most likely from the clutch cover, early SV's are well known for this and it is the reason why the one piece cover was introduced in 2002.
As already said, degrease the engine then take it for a short ride and you will see where the leak is coming from. A bit of silicone sealent will solve the problem.
Old 29-09-08, 06:56 AM   #8
defiant
Thanks Dave,
Do i need to drain the oil before removing the cover?
Old 29-09-08, 07:01 AM   #9
Dangerous Dave
It all depends on the angle of the bike when it is on the side stand, you will have to drain the oil if you have the bike upright on a paddock stand.
I take it you have identified where the leak is coming from?
Old 29-09-08, 07:09 AM   #10
defiant
Gonna take a look when i get home this evening but it does seem to be the clutch cover. I'll clean it and take it for a spin first though.
Thanks...
Help oil leak puter killer SV Talk, Tuning & Tweaking 8 08-01-08 12:29 PM
Oil Leak glade SV Talk, Tuning & Tweaking 15 08-06-06 09:39 AM
oil leak? will SV Talk, Tuning & Tweaking 4 04-03-06 05:01 PM
Oil leak - help! Warthog SV Talk, Tuning & Tweaking 9 03-02-06 04:09 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
