Old 03-10-08, 11:37 PM   #1
dirtsk8
Default Geeky advice
Speed Up Firefox
There are some settings in Firefox that can be changed to increase the speed of loading web pages.
If you're using Firefox on a broadband connection...this will speed up your browsing significantly.
  1. Type "about:config" into the address bar and hit return. Scroll down and look for the following entries (open a new window to do this):network.http.pipelining
    network.http.proxy.pipelining
    network.http.pipelining.maxrequests
    Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
  2. Alter the entries as follows: (double click the entry to change) Set "network.http.pipelining" to "true"
    Set "network.http.proxy.pipelining" to "true"
    Set "network.http.pipelining.maxrequests" to some number like 30. (This means it will make 30 requests at once.)
  3. Lastly right-click anywhere and select New-> Integer. Name it " nglayout.initialpaint.delay " and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives
Works brilliantly for me, but I'm not gonna accept any blame if you bork your browser!
Can you out-geek that?
Old 04-10-08, 12:55 AM   #2
Baph
Default Re: Geeky advice
It's late, and I've just finished setting up this machine. I won't post my iptables rules that do fancy things like forcing transparent squid proxy, and only allowing VNC via XDMCP after I've sent a certain email...
Old Firefox advice BTW.
doing me ed in. (geeky) timwilky Idle Banter 11 04-09-08 08:00 AM
yippee just been given an interesting job. (Geeky) timwilky Idle Banter 4 30-07-08 04:42 PM
Geeky Thread: HP to buy EDS... Baph Idle Banter 8 13-05-08 03:55 PM
EVE Online- yes, it's a geeky thread northwind Idle Banter 58 18-09-07 07:53 PM
nerdy geeky question? hovis Idle Banter 4 25-01-07 12:33 PM
