Old 10-10-08, 10:01 PM   #1
mikey devon
Default fuel tank breather
hi everyone ...can anyone tell me if its normal 4 a k8 2 drip small amounts of fuel thru the breather when stationary b4 i go back 2 dealer thanks
Old 10-10-08, 10:24 PM   #2
aadeyc73
Default Re: fuel tank breather
Is this happening all the time? Are you trying to get too much fuel in the tank?
Old 10-10-08, 10:42 PM   #3
mikey devon
mostly in warm weather. tank is nearly empty light just come on
Old 11-10-08, 04:14 AM   #4
BigBaddad
corrosion!!!!!!! I don't know about pointy's, but had/have a similar issue with my curvy.
The breather pipe runs through the tank and has corroded through on my bike causing it the drip fuel, I've just bodged a repair with some tube and some pet-seal (Still looking for a good black curvy tank). My guess is the because the breather for the rad on the curvy T's into the breather for the fuel tank, condesation builds up and causes corrosion.
Old 11-10-08, 11:04 AM   #5
sv650k4
mine dosnt drip.and i really really cant see your tank being corroded on K8 model so i dont think that will be the cause.
Old 11-10-08, 12:02 PM   #6
Not good, pressure test tube and see if it fizzes the fuel with a full tank.
Old 11-10-08, 12:50 PM   #7
BigBaddad
k8 missed that...won't be corrosion for another few months.
Old 11-10-08, 12:53 PM   #8
But a manufacturing defect is also a possibilty if they haven't bonded the tube into the tank properly.
fuel tank mikey devon Stuff Wanted 2 05-04-09 10:28 AM
oil catch tank / oil breather help. Nicky S SV Talk, Tuning & Tweaking 10 13-01-09 01:13 AM
Petrol Tank Breather & Drain Hoses DarrenSV650S SV Talk, Tuning & Tweaking 3 17-03-08 06:07 PM
fuel tank breather timwilky SV Talk, Tuning & Tweaking 4 22-01-06 09:06 PM
Petrol tank breather hose trick SV Talk, Tuning & Tweaking 5 10-09-05 11:55 PM
