Old 12-10-08, 05:40 PM   #1
heirpin
Default Water Pump seal change
Just about to replace the seals/gaskets etc and hopefully cure the oil leak but have been quoted an astronomical £30 for some Suzuki Bond which is needed according to the official workshop manual.
Is there an alternative that doesn't cost the earth or will some simple RTV do the job just as well?
Old 12-10-08, 07:06 PM   #2
Spikenipple
Spikenipple's Avatar
Default Re: Water Pump seal change
Use Blue or Red (aero grade) Hylomar. It's brilliant stuff, used on all major joins of RR jet engines!
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 12-10-08, 09:22 PM   #3
heirpin
ta for that, where do I get it from? Do you know Mike Smith from Yate?
Curvy Water pump SVDragRacer Stuff Wanted 2 22-03-09 11:58 AM
K2 Water Pump Housing andy1505 Stuff Wanted 2 06-02-08 01:33 PM
205 pugi DTi water pump... Richie Idle Banter 2 01-12-07 04:46 PM
Water Pump....leak 21QUEST SV Talk, Tuning & Tweaking 9 07-11-07 09:02 AM
water pump casing for 99 650 Styler Stuff Wanted 2 02-07-07 03:51 PM
