Old 16-10-08, 08:14 PM   #1
mikey devon
Default tre
can any 1 answer this plz.. my k8 650 has been running rough at 4000 revs when hot.. was going 2 fit a smart tre 2 see if things improve .if they don,t and i remove it is there any way dealer could tell its had 1 fitted when its plugged in2 dianostics. thanks in advace
Old 16-10-08, 08:17 PM   #2
Girth
Default Re: tre
Do a search for timing retard eliminator.
Old 16-10-08, 08:22 PM   #3
mikey devon
Default Re: tre
done that n thats why i posted it here..
Old 16-10-08, 10:30 PM   #4
Mr Speirs
Mr Speirs's Avatar
Default Re: tre
There is something wrong with your bike. The TRE won't fix it. It actually doesn't do anything and you can DIY it using nothing more than a pair of snips and with a pointy a resistor.
Not sure whether the dealer can see whether one has been fitted but as it is a K8 isn't it still under warranty? Go back to the dealer and get it fixed then think about the TRE.
Old 17-10-08, 07:39 AM   #5
Dangerous Dave
Default Re: tre
It won't help with the problem you have, here is a previous post I have made on here....
Originally Posted by Dangerous Dave View Post
Not all this crap again....
Wouldn't waste money buying the product and I wouldn't waste time DIY'ing it either.
The SV650 is only very slightly retarded, there are no gains to be had other than the imaginary butt dyno thinking otherwise. It has been proven and tested so many times, it makes no performance increase!!!
The products (G-Pack, etc...) are aimed at bikes which actual do have a lot of a ignition retard, the problem is the product list lists the SV650 in its fitting guide and everybody reads the hype and product blurb and instantly beleives it will do the same to their SV650. This is utter rubbish, the product description/blurb is aimed at Hayabusa's, GSXR's etc, not a SV650!
Countless tests by proper SV650 tuners have proven it does not work and the people that say it does state the same thing "I fitted it and went for a ride a felt a real difference", this is your imaginary butt dyno telling you you have just increased the power by 10bhp because you fiddled with something!!! Utter rubbish....
Sorry, rant over now and I am climbing back into the straight jacket.
Old 17-10-08, 09:23 AM   #6
Mr Speirs
Mr Speirs's Avatar
Default Re: tre
DD you could put that on permenant copy and paste.
Old 17-10-08, 09:30 AM   #7
Dangerous Dave
Default Re: tre
I might just have to at this rate....
Old 17-10-08, 09:40 AM   #8
simesb
Default Re: tre
Do you have a link to any of these tests?
Old 17-10-08, 07:24 PM   #9
mikey devon
Default Re: tre
thanks for your advice guys... will go back 2 dealer even though he says it s a typical sv, nothing wrong with it
Old 18-10-08, 01:05 PM   #10
Dangerous Dave
Default Re: tre
Speak to any true SV tuner, the usual known BS'ers will tell you it works but the professionals will tell you the truth!
