Old 21-10-08, 12:57 PM   #1
hovis
Default meta 3 alarm and battery drain?
how much of a drain is it on the battery, how long will it take to flatten the battery, and if leaving the bike for some time, whats the best to prevent the battery flattening?
is there a sleep mode, if so hows it activated?
Old 21-10-08, 01:01 PM   #2
Paws
Default Re: meta 3 alarm and battery drain?
put the bike on a trickle charger (like a optimate)
Old 21-10-08, 01:02 PM   #3
hovis
yeah......... i just did, but was looking for some advice on how long it can be left without doing this
Old 21-10-08, 01:15 PM   #4
hovis
aslo.......... what sort of drain do hotgrips have on the battery if left on, ie how long can the accidently be left on without affecting the starting power?
Old 21-10-08, 01:30 PM   #5
Woz
Sleep mode activates automatically after ten days. The longest I've left mine is about 4 weeks and it started just fine.
Old 21-10-08, 01:30 PM   #6
fizzwheel
fizzwheel's Avatar
I think the Meta goes into sleep mode after a month of the bike not being used i.e. the ignition not turned on. Then the battery on my GSXR held enough charge to start the bike for about 3 months, but it totallly toasted the battery and it wouldnt hold charge after being deeply discharged by the alarm.
If you have an optimate I'd leave it connected when you're not using the bike.
As for hot grips, they dont take long to flatten the battery, I reckon a couple of hours probably before its flat but I'm not 100% sure.
Old 21-10-08, 02:02 PM   #7
600+
hot grips - if it's the latest oxford version with the digital control they will not switch unless there is enough power
Old 21-10-08, 06:03 PM   #8
Durbs
Depends what state your battery is in really. When mine was on its last legs, cold weather + 5 days with alarm on would be enough to drain it fully.
Old 22-10-08, 07:43 PM   #9
AmigaNut
Question Re: meta 3 alarm and battery drain?
The manual says the alarm enters sleep mode i.e just imobilser after 10 days.
Removing battery with meta alarm Whitty SV Talk, Tuning & Tweaking 2 12-02-07 08:38 PM
alarm fuse meta v2 catmad SV Talk, Tuning & Tweaking 1 17-01-07 04:19 PM
META Alarm....HELP with immobiliser! thepyrofish SV Talk, Tuning & Tweaking 12 01-04-06 06:54 PM
Meta Alarm Help!!! Samurai Bikes - Talk & Issues 5 09-02-06 02:52 PM
Does anyone know how much current Meta alarm drains battery muddycoffee SV Talk, Tuning & Tweaking 3 01-01-06 10:25 PM
