Old 22-10-08, 04:44 PM   #1
Philbo
Default Rear wheel balance
I just had my tyre refitted to a repaired wheel by a garage local to my work, nice bloke, didn't charge me either! Only thing is he's telling me that the rear wheel of a K7 GSXR 750 doesn't really need balanced...I tried explaining that it had a balance weight fitted before it was repaired, but he was adamant that it wasn't required...
So, is he talking b**ll*cks or not? Any takers?
Not sure if I should just re-fit it and see, but I'd rather not find out the hard way.
Old 22-10-08, 04:58 PM   #2
petevtwin650
Default Re: Rear wheel balance
Whilst you won't feel it as you would a front wheel inbalance, I'd have thought it would be working the rear shock all the time. I'd not be happy with that myself.
Old 22-10-08, 05:11 PM   #3
Blue_SV650S
Balance it yourself ... stick the spindle in, either end on axle stands, wheel free to rotate.
Heavy bit will come to rest at the bottom. Add weight 180deg from it (at the top) ... rinse and repeat until it isn't really settling in any one place any more ...
Balancing the rear wheel isn't as important as the front as you won't 'feel' it as much ...
As for wearing the shock ... bumps in the road do enough of that for you ... as does the chain flapping about!!
Old 22-10-08, 05:16 PM   #4
Rear doesn't matter so much
Old 23-10-08, 10:08 AM   #5
Dangerous Dave
It does need balancing, if he has tested it and says it needs no weights added I would be very surprised!
Old 23-10-08, 10:10 AM   #6
Blue_SV650S
I've had it a few times ... it's not THAT improbable ...
Old 23-10-08, 10:10 AM   #7
Especially if you match light spot of tyre with imbalance of wheel on its own
Old 23-10-08, 01:16 PM   #8
pmapp
pmapp's Avatar
The can be balanced by rotating the tyre on the rim. My mates fancy pants balancing machine for cars can tell you where it needs to be.
Old 24-10-08, 09:44 AM   #9
Ceri JC
Not something I have first hand experience of, but I'm pretty sure I've read certain wheels/tyres have marks on them to allow you to align the light bit of the tyre with the heavy bit of the wheel or vice/versa. That's not to say they won't need balancing, just that it'll be less likely to and less out by default.
Old 24-10-08, 10:38 AM   #10
Yeah, ironically really well balanced wheels can need more weights with the tyres on, because usually you counter the imbalance of the tyre with the imbalance of the wheel.
Does an 'N' rear wheel fit an 'S'? davepreston SV Talk, Tuning & Tweaking 8 11-05-09 01:25 PM
rear wheel antony SV Talk, Tuning & Tweaking 5 26-05-08 01:22 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
cbr rear wheel yorkie_chris SV Talk, Tuning & Tweaking 33 20-02-08 11:09 PM
Rear wheel on K4 and K2 opsman Bikes - Talk & Issues 1 27-12-06 01:02 PM
