Old 29-10-08, 05:34 PM   #1
neillfergie
Default Suspension raising
Whilst looking on Ebay today at work (as you do) i noticed these. . .
http://cgi.ebay.co.uk/Suzuki-SV650-0...d=p3286.c0.m14
Now they claim to boost the rear suspension by 40mm which would make my life a whole lot easier as i find the bike a tad low and i feel like all my weight is over the back tyre.
Question is will this make the bike,
a. a bit too keen to lean into corners and feel a bit top heavy
b. too nose heavy and more likely to low side in a fast corner?
Not sure if this helps but. . .
my suspension compresses quite a lot when im on the bike. I weigh about 19st + leathers etc so ive got all but the last two clicks of rear preload on already.
Discuss
Old 29-10-08, 05:40 PM   #2
Dangerous Dave
Default Re: Suspension raising
They are called jack-up kits, as you said they raise the rear up or down depending on there length.
They will help increase turn in, they won't add much noticeable weight the the front and they won't make it more likely to low side.
Old 29-10-08, 05:41 PM   #3
Biker Biggles
Biker Biggles's Avatar
That would raise the rear,but if you are 19 stone I think the problem is that the bike is undersprung for you.So it wont solve the issue.You really need higher rate fork springs and rear spring.Adding preload helps,but doesnt really solve it either.
Raising the height of an SV BigBaddad SV Talk, Tuning & Tweaking 11 25-05-07 04:36 PM
Raising handlebars? Bullwinkle SV Talk, Tuning & Tweaking 8 03-04-06 02:10 PM
raising the REAR! suzsv650 SV Talk, Tuning & Tweaking 1 12-05-05 06:57 PM
raising tail shutdown SV Talk, Tuning & Tweaking 21 28-04-05 10:24 AM
Tank Raising. DeeJay SV Talk, Tuning & Tweaking 15 14-11-04 05:44 PM
