Old 30-10-08, 01:13 PM   #1
vardypeeps
Default 99 (curvy) Exhaust Stud Things
I took my headers off about 2 months ago and when I was undoing the nuts for the flanges off the studs that go in to the engine block they where stuck fast. Basically I removed the whole stud as the nut has done rusty and got stuck to it.
I have some new studs and nuts but I was wondering if their is an easy way to insert the studs without a special tool. I'm going to do it this weekend as I have a set of swingarm bearing to put in.
Old 30-10-08, 01:38 PM   #2
Default Re: 99 (curvy) Exhaust Stud Things
Just use double nuts on the outside thread of the stud, one locks against the other. Once the stud is in place, then remove both nuts. Plus put a bit of copaslip or copper grease when assembling everything.
Old 30-10-08, 01:40 PM   #3
vardypeeps
Nice one! Simple job then good stuff
Old 30-10-08, 01:43 PM   #4
No problem, I thought you were doing something a bit more complicated, which doing your swinging arm bearing is a bit more technical.
Old 30-10-08, 02:42 PM   #5
Use stainless ones with copperslip
Old 30-10-08, 04:51 PM   #6
Dangerous Dave
+ 1, the perfect way to do it on the cheap and hassle free.
+ 1
Old 31-10-08, 06:49 AM   #7
pmapp
pmapp's Avatar
What sizes are the studs pweeeeese?
Old 31-10-08, 08:33 AM   #8
petevtwin650
This size Phil
HTH
But seriously.
They are M8 but a coarser than standard thread.
I've got a couple here Phil. If you PM your addy I'll pop 1 or 2 in the post to ya. Otherwise any reasonable bike spares shop should have them on the shelf.
Old 31-10-08, 10:30 AM   #9
That looks like the normal metric coarse thread pitch to me... will measure one of my spare heads...
Old 31-10-08, 08:59 PM   #10
vardypeeps
Any chance to show off his shiny pipes!
Cheers chaps I can get this sorted on the weekend along with my swinger bearings.
Farrrk Snapped Exhaust Header Stud Bolt 21QUEST SV Talk, Tuning & Tweaking 25 02-08-08 09:40 PM
Snapped Exhaust stud! spacehog SV Talk, Tuning & Tweaking 4 22-05-08 08:21 PM
Removing Exhaust a Stud Grinch SV Talk, Tuning & Tweaking 50 28-02-08 11:08 PM
black things at top of curvy lowers stooster SV Talk, Tuning & Tweaking 11 29-07-07 09:42 PM
exhaust stud dirtydog SV Talk, Tuning & Tweaking 13 14-02-06 04:07 PM
