Old 31-10-08, 12:38 PM   #1
Cam_73
Default Front cog nut! Arrr!
This little beauty is not budging!
IIRC: 140N.m torque?
Had a mate sit on the bike in 1st hard on rear brake.
Used a half inch drive universal bar and the bike is creeping rather than the nut loosening, tried penetratnt spray, no joy.
Anyone got any tips? Stopped before I broke, ruined, destroyed something on the bike.
Old 31-10-08, 12:40 PM   #2
Default Re: Front cog nut! Arrr!
Maybe take it to a garage with an air impact gun
Old 31-10-08, 12:42 PM   #3
petevtwin650
I just bought a Power Wrench from Netto as the Dukes rear wheel nut is 154Nm
This is it in action. Click on the vid link.
http://s72.photobucket.com/albums/i1...arwheel001.flv
Only cost 20 quid. Wish I'd had one for undoing the Sv sprocket nut and the lower suspension bolts.
Old 31-10-08, 12:51 PM   #4
MrMessy
Try warming nut gently with a blowtorch, jam back wheel against swinging arm with a big lump of wood. Watch for tyre valve! Be very careful with an impact wrench, can smash cogs in gearbox!
MrMessy is offline   Reply With Quote
Old 31-10-08, 01:26 PM   #5
Sean_C
Pete! You have a house elf!
Hehehe.
Nice find Pete, I might have to invest in one. The power wrench I mean.
Old 31-10-08, 02:01 PM   #6
petevtwin650
Hehehe.
Did you mean poor wench Sean or is it just your accent.
I need a breaker bar about 4 foot long to undo that rear wheel nut and the chance of the socket slipping off and scratching the wheel is quite high, so I've been on the look out for one for a while. Wasn't going to pay 60 quid plus for one though.
Old 31-10-08, 03:45 PM   #7
jimmy-james
I had to put a piece of 2inch square between the swing arm and the wheel to stop it from turning and put a scafold pole on my breaker bar to release mine. I didn't lean on it all at once i tried bouncing the pole gradually applying more weight and it eventually came undone. Be careful not to shear the bolt or break the chain!
Old 31-10-08, 06:05 PM   #8
Dangerous Dave
You need more leverage and a heavy/stronger friend!
Old 31-10-08, 06:34 PM   #9
Stu
Trinity
Stu's Avatar
yes
No, just a block of wood through the rear wheel and 1st gear as said before
Old 31-10-08, 09:33 PM   #10
glade
glade's Avatar
does that nut turn the 'wrong' way?
glade is offline   Reply With Quote
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
