Old 03-11-08, 06:15 PM   #1
steveg
steveg's Avatar
Question service question shoud I leave well alone
Quick question the spark plugs and air filter have been in the bike for last 16k ( bike is now at 34k) , have been changing oil / filter every 4k , valve clearances were last checked ( no adjustment needed at 17k miles ) , bike is running great !
Do you recon I need to change plugs & air filter and get valve clearances done or is it ok to leave for another 4k as long as its running fine .
It would be great if I could extend work till after Xmas
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 03-11-08, 07:17 PM   #2
Default Re: service question shoud I leave well alone
personally id leave it, its not going to hurt anything.
Old 03-11-08, 11:20 PM   #3
metalmonkey
I'm no expert here, however what does the service schedule say?
I would go from there, have you even checked the state of air filter and the plugs?
Old 03-11-08, 11:24 PM   #4
I'd check the clearances. Leave the rest of it.
Old 03-11-08, 11:39 PM   #5
alan pasfield
if it aint broke dont fix it
Old 03-11-08, 11:41 PM   #6
But a tight valve clearance can lead to unpleasantness
Old 04-11-08, 01:15 AM   #7
jimmy-james
Do valve clearances not get looser with time?
Old 04-11-08, 01:31 AM   #8
RandyO
shim under bucket tends to get tighter, never heard of them getting loose
skipping valve clearance inspection is NOT something I would recommend, by the time it affects your running, it's too late, and you will need more than adjustment
tight valves will burn the seats, and possibly the valve stems, next thing you know, stems will weaken and break
something I have noticed, following the owners manual, plugs & carb/throttle body sync, clean air filter every 7500 miles... as good as I thought it was running, it always ran better after and the most significant difference in running is instantanous starts
you bike, do as you wish, but I think you will be happier if you do recommended routine mantenance on schedule
Old 04-11-08, 02:02 AM   #9
oldie
We haven't heard from you for a while, RandyO!
I'm curious as to how many miles you have on the SV now, and if you've had any major problems.
regards,
Oldie
Old 04-11-08, 02:30 AM   #10
RandyO
regards,
Oldie
135k, valve guides are toast , I have 31k on my 07 V-Strom 1k now
Service question - K6 tj ready SV Talk, Tuning & Tweaking 17 15-02-09 01:54 PM
Service Question hallasv Bikes - Talk & Issues 1 12-10-08 08:48 PM
SV1000 Clutch - Shoud I be worried Girth SV Talk, Tuning & Tweaking 9 26-05-08 10:15 AM
Leave it or not to leave it, that is the question! Blue_SV650S Idle Banter 23 05-05-08 06:12 PM
service question steveg SV Talk, Tuning & Tweaking 2 02-01-08 09:47 PM
