Old 05-11-08, 10:16 AM   #1
AndyBrad
Default wet visor issues?
Ok folks. Another day another question. After all your help with me getting onto a motorway im back for some more advice.
When riding in the rain I don’t have a problem with getting wet etc. Or if its normal rain it doesn’t seem to pose a problem. However last night when I rode home the rain was that fine misting stuff that gets you wet. I was at town speeds so the water was effectively clinging to my visor. I keep my visor spotless (use a pentax microfiber cloth to clean it before I set out every time) but it made visibility pretty poor to say the least. Now luckily ive got an mg so am used to not having wipers but this want much fun so any tips on riding in conditions like this? Im imagining fog is the same?
Andy
Old 05-11-08, 10:19 AM   #2
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Default Re: wet visor issues?
Easy solution, go to Hein Gericke and buy some of their visor wipes, it is made of rubber. I wear it on my thumb and all it takes is a simple swish with your clutch lever hand and the visor clears.
"Feckinnnn Unluckkeeeeeeee"
Old 05-11-08, 10:34 AM   #3
AndyBrad
would that not scratch your visor if you had salt on it for example?
Old 05-11-08, 10:35 AM   #4
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Hasn't done with mine yet and I have usewd it all last winter and this year whilst it has rained. I guess that would only really be an issue if you were trying to use when the visor was drying.
Old 05-11-08, 10:50 AM   #5
dyzio
dyzio's Avatar
I use this one, no scratches. You can also get some new gloves with an "integrated" wiper.
Old 05-11-08, 10:54 AM   #6
Paul the 6th
Paul the 6th's Avatar
+1 I use them too. You get 2 in a packet for 4 quid. Bit like a mini bit of wiper blade. Only thing is they can sometimes pop off your glove when getting off the bike (I've found 2 of mine outside my office door a few times).
They do work well. Asside from that the only other thing I do is check the metoffice.gov.uk bit for my local area (and surrounding area's to get a wider forecast of what's what)...
Here's yours
http://www.metoffice.gov.uk/weather/...t_weather.html
whack it on your favourites or set it as your homepage - I check mine about 4 times a day to see the changes. Also, metcheck.com and the bbc weather. Between the 3 of 'em you'll suss what's happening
Old 05-11-08, 11:04 AM   #7
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
+1 to weather forecasting...lol.....always looking at them. Those V-Wipes are the same as the Hein Gericke ones I think. Quite easy to split so always put the on the glove and in position before putting hand inside.
Old 05-11-08, 11:10 AM   #8
Mark_h
Mark_h's Avatar
Thin smear of neat washing up liguid causes the water to collect and run-off. Works a treat. Is a really really thin smear which you then almost completely wipe off. Works like rain-ex but much cheaper. Keep a bit of liguid on your bike somewhere too in case you need to reapply. Nice lemon/peach/arctic fresh/ smell too depending on your choice of liquid. Great white-afro comedy helmet hair if you apply too much.
Minister for Sustainability
Old 05-11-08, 11:19 AM   #9
missyburd
Yeah YC has a pair of Halvarssons with a wiper, always using it, seems to do the trick. +1 about the washing up liquid too, definitely helps.
Old 05-11-08, 11:45 AM   #10
Dangerous Dave
Polish a water repellant product on to the visor, there are many to choose from.
oil issues Brettus SV Talk, Tuning & Tweaking 9 24-11-08 08:39 PM
3 Issues Phaelok Bikes - Talk & Issues 11 28-10-08 11:06 PM
Anti Fog Visor - Breath Guard or Visor insert Stu Bikes - Talk & Issues 50 14-11-07 10:17 AM
DNS Issues Jelster Idle Banter 6 05-02-07 05:59 PM
Visor Issues Ping Bikes - Talk & Issues 16 09-11-05 09:24 PM
