Lucky it was only at low speed:
![]() ![]() ![]() K7 pointy with 1600 miles on the clock, thought twas a slack chain that was causing the dodgy upshifts. Any idea what caused it or what I need to do to fix it? Anybody else had this happen? ![]() Last edited by hob; 18-11-08 at 03:20 PM. |
All you need is a circlip - so about 50p to fix.
Had that happen to me after the circlip had been weakened when it was taken off using screwdrivers rather than circlip pliers when I had the other associated failure of the pointy gear pivot when the whole bolt comes out of the frame.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Many thanks
![]() Twas around vauxhall when it broke lol ![]() |
Circlip and a washer it would appear.
LOL - I got my replacement circlip from a motor factors down at Stockwell, gave me it and a couple of others for nothing so was a free repair for me.
Good to see that Suzuki have addressed this cheap and easy to fix (not to mention potentially very dangerous) flaw in the SV since we brought it to their attention in 2004.
//SarcasmModeOff |
#7 | |
Suzuki wouldn't order me in any as "I would have to pay for the parts before ordering" Just got some from halfords 300 for £7 lol one must fit ![]() |
Fixed
![]() Righty ho then, the halfords kit: http://www.halfords.com/webapp/wcs/s...d=-1&source=td or "Halfords External Circlips HBB129" Contain a fitment that will "fit" There were two types one that would fit on by hand (if you pull on the sifter it will pop off) or the type that need pliers to apply (can't oull off by hard pulling!) I chose the later one. More interestingly (and the point of another post ![]() The only reason for the washer (that I can see) is to stop the minimal movement of the shifter, however even with the free play, the washer less one was considerably stronger, so much that the bike could be pulled over with just the shifter ![]() I have decided to run washer less, I doubt the washer I have are any different to the suzuki ones (same with circlip) so maybe the washer causes early failure? There was a spanner monkey around that area though, the rubber foot shifter was loose ![]() Will take the "pop on by hand" ones with me (keep in bag) so that should for some reason it pop off again I can temp pop it on to fix it ![]() |
Is it not possible to get the gear shifter off the footpeg assembly? | Jase22 | SV Talk, Tuning & Tweaking | 3 | 17-08-08 06:15 PM |
green plug in frame, above shifter | oconnor | SV Talk, Tuning & Tweaking | 6 | 29-01-07 07:56 PM |
Gear shifter linkage rod | Razor | SV Talk, Tuning & Tweaking | 5 | 05-01-07 11:26 PM |
linkage/shifter help | jimmybluedevil | SV Talk, Tuning & Tweaking | 5 | 08-12-06 08:48 PM |
Clip-on, upper fairng, and shifter unit. | ruf_rider | SV Talk, Tuning & Tweaking | 1 | 04-08-05 11:26 AM |
