I've got a pair of 750 k6 forks that are absolutely mint. (want to use them as they are black rather than gold). I'd like to use a pair of k4/5 750 yokes but i'm unsure if they'll fit. The k6 fork is 50mm diameter for the top yoke and 53 or 54 for the bottom. Is there anyone out there who knows what the dimensions are for the earlier yokes. Ta Paul
GSXR 750 SRAD
Top Yoke - 50mm Bottom Yoke - 54mm GSXR 750 K early series Top Yoke - 50mm Bottom Yoke - 54mm Last edited by Dangerous Dave; 23-11-08 at 05:53 PM. |
Cheers Dave,
Sounds like the yokes are the same. Recon I can get a k4/5 top and bottom yoke and then buy a new wheel (from Delkevic) and use that! Less hassle with the steering stops, ignition switch, etc. Anyone know of any probs out there? |
What model SV have you got again?
A Delkevic wheel is quite costly, you can find cheaper secondhand ones in great condition. PS. like the signature. |
I did PMSL when I read that thread! How you two doing? I'm still keeping this htread quiet from other half
![]() Actually, I can't find much on fleabay, and nothing drastically cheaper... I've got a pointy K3 in Blue, so the black forks will go better than the gold. |
Engaged
In that case yes, it should all fit together. Double check the disc sizes first, can't remember the diameters off of the top of my head, as you may need to space the callipers back or use the larger disc's. |
You don't want SRAD yokes for the curvy. Yokes from the later gixxers will drop right in. See the link the greek boys signature.
#9 | |
#10 |
Should that 1mm make a difference? I would have thought that there would be enough play in the bottom yoke to take this into account.....
.... Of course I have been know to be wrong...... |
GSXR Front Wheel and Upper Yoke | CheGuevara | Stuff Wanted | 0 | 15-05-09 09:27 PM |
How to remove top yoke/fork bracket? | sam anon | SV Talk, Tuning & Tweaking | 7 | 07-02-09 09:48 PM |
GSXR 600 K1 Forks & Bottom Yoke for SV650 K3+ Conversion | Ter | For Sale - SV's and SV related items | 9 | 21-04-08 08:00 PM |
Gsxr 600 Top Yoke | richwill68 | Stuff Wanted | 4 | 27-03-08 03:11 PM |
SV GSXR Fork Swap - Keep Stock GSXR Damper? | Mesomorphman | SV Talk, Tuning & Tweaking | 5 | 08-09-06 07:40 PM |
