Old 29-11-08, 07:23 PM   #1
Default Custom length brake hoses
Where can I get custom length brake hoses? Not braided. Just standard
Old 29-11-08, 07:24 PM   #2
Default Re: Custom length brake hoses
No point using rubber.
You can make your own braided.
Old 29-11-08, 07:25 PM   #3
Dangerous Dave
Don't know about standard but Hel and Goodridge offer custom length braided ones which will cost not much more depending on length.
Old 29-11-08, 07:26 PM   #4
Don't want braided. Just rubber
Old 29-11-08, 07:26 PM   #5
Dangerous Dave
Why must they be rubber?
Old 29-11-08, 07:28 PM   #6
I don't want them too powerful.
Old 29-11-08, 07:29 PM   #7
Which will be wrong
You're seriously mental to want rubber hoses! They will be hard to find, will cost more than braided and be knackered within 5 years.
If you want them to look OEM, use black braid, or matching your bikes colour, or cover them in heatshrink sleeve.
Old 29-11-08, 07:30 PM   #8
The material of the hose does NOTHING to the power of the brakes unless your lever is coming back to the bar as it is now.
You are developing pressure in the line, slight expansion takes up volume but pressure is the same.
Old 29-11-08, 07:31 PM   #9
Dangerous Dave
New rubber and new braided are the same, what braided offer is longevity because they don't start to bulge like rubber hoses.
There is no difference in power, a slight difference in feel through the lever and consistency is the main difference with braided lines.
Which will be wrong
I've heard other peoples comments but to date I have never had an issues.
Old 29-11-08, 07:36 PM   #10
Tilt
Goodridge have a range called colour flex which (so you can have black if you want) with various other fittings they supply allow you to do anything you want.
http://www.goodridge.net/uk/pdf/Good...alogue2007.pdf
if you want lesser performance then leave some air in when you bleed
Rear Brake hose length - Naked vs Faired DarrenSV650S SV Talk, Tuning & Tweaking 4 11-03-09 08:15 PM
Hel Brake Line Length Biker_Billy SV Talk, Tuning & Tweaking 7 27-03-08 10:33 PM
Brake hose length, pointy vs curvy 2pc race kit Tim in Belgium SV Talk, Tuning & Tweaking 7 20-02-08 04:20 PM
Brake Line length Torn-Thorax SV Talk, Tuning & Tweaking 2 10-03-07 02:26 PM
Hel Brake Hoses kevbuck SV Talk, Tuning & Tweaking 23 22-12-04 01:31 PM
