Old 01-12-08, 10:31 PM   #1
jaffacakes
Default Camcorder cables
I have recently found an old camcorder with old "compact video cassete"'s in the bag containing oldish home movies. However, I do not have any cables to connect it to either my TV/dvdrecorder or PC. It has A(yellow) + V(white) out:
and here is the front of my PC - It has a "Composite" socket (yellow)- I don't have the faintest idea what it is for!
Sorry images are fuzzy, I had to use my ****ty phone!
Is there a cable to connect the AV out to the composite and If so, is there software out there for free? I managed to connect my old turntable up to my pc without any problems but my brain is a bit full at the moment with other stuff and cant get my head around it!
Old 02-12-08, 12:29 AM   #2
Grinch
Default Re: Camcorder cables
Well if I remember correctly yellow is video and white is normally left audio or mono.
The s-video can take a av cable with a converter or just use the composite direct, but both do not take a sound feed, your need to plum that into your sound card. AV to phono converter or something, should be able to get them from Maplins.
All this depends on that plug in on the front of your PC being the connection to a video capture card, so if you not sure have a look about the software on your PC, as if it came with the PC its normally bundled as a whole. Might be a CD/DVD laying about that you haven't installed yet. If its not installed then I would suspect those are video outs rather then video in.
What model PC is it.
Old 02-12-08, 07:12 PM   #3
jaffacakes
Its a HP Pavillion t849.uk
Penium 4 3ghz 2.5GB Ram
Windows XP Servicepack3
**** software - Intervideo or Moviemaker (which has an error as soon as it start saying it needs to shut it down)!
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
Harddrive Camcorder sandman Track Days 17 18-05-08 10:45 AM
Camcorder Hi-8 Grinch Idle Banter 6 30-05-07 09:55 AM
Recommend a Camcorder Demonz Idle Banter 7 21-06-06 11:07 PM
Which Camcorder sevy SV Talk, Tuning & Tweaking 2 11-07-03 08:45 AM
