Old 02-12-08, 12:50 PM   #1
vardypeeps
Default Xbox 360
Afternoon fellow SV'ers
I have noticed a few people have got their XBOX ID in their signature and was wanting to ask a question.
Has any one on here ever had the 2 red lights issue with their xbox and managed to fix it? All help would be greatly accepted!!!
Mine is in bits at the moment waiting for a new fan to arrive as well as other bits but has anyone fixed the problem?
Old 02-12-08, 01:44 PM   #2
Grinch
Default Re: Xbox 360
Yes, I sent it to Microsoft.
Old 02-12-08, 02:01 PM   #3
Alpinestarhero
If its the full ring of death, try wrapping the xbox in a towel and turning it on for a bit. My freind fixed his xbox this way - metled some broken conections back together
Old 02-12-08, 02:52 PM   #4
custard
think the 2 segments to the right comes up as E74(??). mine has gone this way and as yet havent bothered to fix it. have been told by peeps on here that it has something to do with the av cable but have yet to replace.
Old 02-12-08, 02:57 PM   #5
That sounds like utter stupidity and just dumb luck that it worked.
Old 02-12-08, 03:02 PM   #6
Miss Alpinestarhero
Its actually worked for loads for people...
Old 02-12-08, 03:28 PM   #7
Alpinestarhero
You'd think that wouldnt you? But the early Xbox consoles had curcuitry done using poor quality solder (high in lead i think), and localised hot-spots inside the console (causing things to expand at differant rates...you know the score) caused connections to physically break. My mate found a forum suggesting wrapping the xbox on a towel and turning it on - several people reported success. He has nothing to loose anyway! With no heat being able to escape, the whole console got hot, not just localised parts. So everything could melt back together I suppose
Old 02-12-08, 03:32 PM   #8
AndyL
http://www.llamma.com/xbox360/repair...rror-codes.htm
Old 02-12-08, 03:37 PM   #9
SoulKiss
SoulKiss's Avatar
Error code 321: You were dumb enough to by Hardware my Microsloth.........
Old 02-12-08, 03:49 PM   #10
DanAbnormal
So far I've had a few Xbox's die on me. I think I'm on number 3, 4 or 5. I can never quite remember. I've also had one power unit fail as well. My elite is now on it's way out. Have had a few issues with the display showing a checkered pattern which is a bad sign that the gfx chip is on the way out. Ah well, at least MS are very good with replacing it!
xbox 360 newts924 Idle Banter 11 25-07-08 06:14 PM
ps3 or xbox 360 ocr_sv Idle Banter 19 06-05-08 12:14 PM
Xbox 360 Alpinestarhero Idle Banter 16 15-02-08 08:59 AM
PS3 vs Wii vs XBox 360 Baph Idle Banter 39 06-07-07 11:10 AM
Xbox 360 rob13 Idle Banter 15 08-05-06 06:14 PM
