Old 20-12-08, 05:47 PM   #1
scottjames
Default Gsxr levers
are there any gsxr levers tht will fit a curvey?
i have seen some aftermarket gsxr levers and wondering if they will fit my curvey.
could some one tell me years and models that do if there are any.
cheers guys
Old 20-12-08, 05:52 PM   #2
Alpinestarhero
Default Re: Gsxr levers
I dont think so, i think (certainly for the brake lever) it would be of a differant size to fit the pivot point and to operate the master cylinder.
VFR400 NC24 brake levers will fit though, if my quick eyeball at the one on my dad NC24 is anything to go by
What do you want other levers for anyway?
Old 20-12-08, 06:06 PM   #3
scottjames
super bike January has some nice leavers like pazzo but only 35 quid. unfortunately they only do em for the variations of gsxrs.
so im wondering if any of them will fit the curvey. mainly the clutch lever.
Old 20-12-08, 06:19 PM   #4
Dangerous Dave
I thought Pazzo made there own levers for the SV?
Are you after any particular type of lever? If not search Ebay, although any cable clutch perch will fit onto an SV so you could use a Pazzo GSXR lever and source a perch.
Old 20-12-08, 08:37 PM   #5
Yeah, that's exactly what I did, GSXR Pazzos are quite common used so I got a whole clutch lever and perch assembly, and a Pazzo lever, for about £40, sold the SV kit, and I've still got a spare
Old 20-12-08, 09:36 PM   #6
drag
What the hell, gis us a bit more info there mister !!
Old 20-12-08, 09:41 PM   #7
Just ebay at its finest really. The Pazzo was £30, as new but slightly used, the clutch perch and lever were a tenner. Worked out well!
Old 20-12-08, 10:01 PM   #8
drag
You canrt say fairer than that really, any specific model of gsxr's ?
Old 20-12-08, 10:04 PM   #9
Mine is some sort of thou... But it'd work fine with others, I've used SRAD mounts on an SV as well. A cable clutch is a cable clutch, pretty much. Oh, I don't use the clutch-pull interlock switch that stops the bike from starting, so that might complicate matters, really not sure as I've never looked at it really.
Old 20-12-08, 11:21 PM   #10
skyline
You'd have to disable the clutch switch somehow if you use a different clutch perch though, is that right? I think you'd have to solder two wires together so the bike can start without pushing the clutch lever in...
ASV Levers DarrenSV650S SV Talk, Tuning & Tweaking 9 10-02-09 10:17 PM
GSXR Calipers & R6/GSXR Master Cylinder Steve_God Stuff Wanted 4 16-02-08 06:30 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
