Old 22-12-08, 02:06 PM   #1
twopots
Default Rear brake caliper pin
I tried to remove the rear brake discs over the weekend, but stopped a bit short by the pin.
Probably seems like a bit of a stupid question but do the rear pins from K3 onwards simply screw out using an allen key? I was about to give it a goe bu tthough a bit wiser to ask the question first before I end up breaking something...
I've seen alot of threads and advise about drilling holes etc...does this apply too the older models ony?..
Old 22-12-08, 02:11 PM   #2
Viney
Default Re: Rear brake caliper pin
I take it you mean brake pads? Not sure about a K3 rear caliper. If they are the same as the earlier models, then no, they will probably be siezed in the caliper for sure. Try getting a set of locking molegrips on the pin between the pads and giving them a wiggle! Try some penertrating oil in there as well
Old 22-12-08, 02:15 PM   #3
twopots
yes the pads.. thanks I'll give it a try
Old 22-12-08, 02:25 PM   #4
Alpinestarhero
Mole grips, heat, wd40. wiggle lots. bash with hammer. wiggle, wd40, wiggle, swaer, wiggle, contemplate cutting them, wiggle some more, keep going for 2 hours and they'll come out.
Mine did
Old 22-12-08, 02:42 PM   #5
thedonal
And then lashings of copper grease when it goes back in again.
Was quite chuffed on the weekend as I had to replace rear brake pads- last serviced the caliper in Jan, pins came out with no bother.
Old 22-12-08, 03:14 PM   #6
Alpinestarhero
While your at it, replace the dust seals and put on copious amounts of red brubber grease on the pistons (take them out and clean the whole caliper up).
If you havnt already, do the same with the front calipers.
Old 22-12-08, 03:21 PM   #7
Why would you replace the dust seals and not just have a gander and see if they need it?
Old 22-12-08, 03:25 PM   #8
Alpinestarhero
thats true...but if mine were anything to go by, they could be stretched a bit by now and a bit crappy.
Old 22-12-08, 03:29 PM   #9
Boil them in water. You can get lucky and they spring back into shape. However, a slighty saggy dust seal won't do that much harm if the rest of the caliper is serviced properly.
Old 22-12-08, 03:30 PM   #10
Alpinestarhero
ah, interesting, didnt know that
Where can I buy SS Rear Brake Caliper Pin ? leegriffiths128 SV Talk, Tuning & Tweaking 4 22-08-08 02:19 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear brake caliper madderdog SV Talk, Tuning & Tweaking 9 15-12-07 01:30 PM
Rear Brake Caliper! Phantomtek Stuff Wanted 5 07-07-07 03:17 PM
Rear brake caliper Viney Bikes - Talk & Issues 6 07-03-07 10:47 PM
