just wondered if there were ne posts on here about my title. thanks
#2 | |
Use the search function
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
yeap been done many times before. vzzzbxt has some bits for sale too.
Nope, never heard of that one.
yer new its been dun many times b4 but just wondered if ne body knows of a detailed post about it on here so many posts to go through just thought some would remeber seeing one
Yup there's plenty people done moderately detailed write ups, and given lists of parts, and what bikes you can get them from, and how to put them together.
ah but noones said they'll fit it for him...............
I will if he's paying enough
#9 |
#10 |
Keep it simple, for USD forks what you need is the entire GSXR 750 SRAD (1996-1999) front end for a Curvy and for RWU forks the entire GSXR 600 SRAD (1996-2000) front end (bear in mind many GSXR parts are interchangeable between models)....
Yokes, Forks, Wheel, Spindle, Brake Discs, Brake Calipers, and the Fender. In addition you will need TL1000S clip-ons for the 750 forks as the GSXR ones are two low and the throttle cables will damage the fairings. To make it all work the simplest method is to buy a bearing from Twin Works Factory, this replaces the top bearing on the SV and allows for the bigger SRAD stem to pass through. The lower SV bearing can be retained as it is a shared part with the GSXR's. I have fitted 27 front ends to Curvy's in the past 9 years, and 4 have had steering lock alignment issues (which is a bit strange for a mass produced bike and parts). The simplest way to over come this, and the best if you want to return to the SV front end in the future, is to file off 1mm from the SRAD's right hand side steering lock tab. This will allow the SV's handle bars to lock and cause no permanent damage to the bikes frame or ignition barrel. SV800S Another method to mount the yokes, without the TWF bearing is a little more time consuming. You need an SV steering stem for the SRAD bottom yoke, however it is a smaller diameter than the SRAD's so you will have to braze some metal on and then mill it down to the correct size. A shim (spacer) is also required for the top yoke as the SV steering stem is a smaller diameter up there too. The advantages of this method is that the bike retains all its original headrace bearings, thus making them easier and quicker to get hold of. The one problem you will be left with, whether you go USD or RWU is the speedo. The SV650 runs it speedo off of the front wheel and the SRAD wheel has no location for it and the SRAD spindle has no space and is to large a diameter to except the speedo unit. There are three option to take, one is to run with no speedo, another is to use a Hall Effect sensor (Northwind and Yorkie Chris are your experts here ![]() The above USD fork option is only applicable to Curvy SV's (1999-2002). |
gixxer front end, TLS mudguard | yorkie_chris | SV Talk, Tuning & Tweaking | 12 | 31-12-08 03:24 PM |
Gixxer front end up and running! | richwill68 | SV Talk, Tuning & Tweaking | 12 | 30-05-08 05:45 PM |
gixxer front disks....... | Svkid | SV Talk, Tuning & Tweaking | 1 | 24-02-08 09:06 PM |
Gixxer front end | BoltonSte | SV Talk, Tuning & Tweaking | 7 | 30-08-06 02:30 PM |
Which clip ons for gixxer front end? | ianofbhills | SV Talk, Tuning & Tweaking | 6 | 03-08-06 09:37 PM |
