Old 19-01-09, 03:26 PM   #1
Stu
Trinity
Stu's Avatar
Default Caliper seal
Everyone seems to be servicing their calipers these days so where did you get your replacement seals from? & how much?
Took the rear off my ZX6R and it looked like the seal was stiking past the piston at one point & I couldn't push the piston back into the caliper.
I believe the rear on a ZX6R is the same as an SV caliper.
Old 19-01-09, 03:41 PM   #2
Default Re: Caliper seal
http://www.wemoto.com/
Here's a good start. Think you get a tub of red rubber grease in the service kit. Prices are ok too
Old 19-01-09, 03:56 PM   #3
Ceri JC
Yes, the wemoto kit is good. Contains all the rubber parts of the calipers, and not just the piston seals. As you say, also includes a tub of red grease equivalent (actually pink in this IIRC ).
As to compatibility with other bikes, yes lots of other bikes share the same size/type of caliper seals. I once ordered some Suzuki ones and was given official Honda parts! They were exactly the same size/type as the Suzuki ones.
Old 19-01-09, 04:17 PM   #4
arcdef
+1 for wemoto, good service and posted very promptly and as said comes with some pink grease so no need to buy anything else, also do most other spares so could get them at same time
Old 19-01-09, 04:32 PM   #5
Stu
Trinity
Stu's Avatar
Thanks, so do I need the full kit or just the dust seals kit?
Old 19-01-09, 04:38 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
If it's just the rear caliper you should only need the seals although some people will say you need to change the small seal in the caliper if you split it
2001 SV650 in shimmerin green, Not broken anymore
Old 19-01-09, 04:39 PM   #7
dirtydog
Knob faced knobster
dirtydog's Avatar
oh and i normally get mine from wemoto as well
Old 19-01-09, 04:51 PM   #8
vzzzbuxt
spares direct are bloody good too
Old 19-01-09, 04:58 PM   #9
Dangerous Dave
+ 1 for wemoto.
Many other manufacturers parts work simply because the bike manufacturer doesn't make the callipers, in the Japanese market they are all either Nissin or Tokico.
Old 19-01-09, 05:34 PM   #10
Thank you, thank you & thank you
Its good to be spot on once in a while
Front Caliper Dust Seal mikebrooman SV Talk, Tuning & Tweaking 5 25-02-09 12:50 PM
refresh caliper seal O ring? ejohnh SV Talk, Tuning & Tweaking 8 01-02-08 11:10 PM
ultra seal? ben650 SV Talk, Tuning & Tweaking 9 20-03-07 11:49 PM
Brake Caliper Seal Kits Tris SV Talk, Tuning & Tweaking 7 08-07-06 09:06 PM
Caliper Seal Kits? rscosworth SV Talk, Tuning & Tweaking 6 16-06-05 06:55 PM
