Old 20-01-09, 03:00 PM   #1
Ed
Default Picking a lock
Help please. I have lost the ket to the garage door - not the up and over, I mean the side door. We only had one given to us when we bought the house, so no spare
Do I have to get a lockie in or is there cheap way of unlocking the door? It's a 3 lever thing, from memory.
Old 20-01-09, 03:03 PM   #2
Sally
Default Re: Picking a lock
Kick the b@stard down?
useful, and fun
Old 20-01-09, 03:06 PM   #3
Jabba
I've seen locksmiths drill enough of these things to know how to do it. Unfortunately, I'm a long way from you
A locksmith shouldn't be that expensive if attending by prior appointment, i.e. not as an emergency call-out.
Cheaper than a new door for sure
Old 20-01-09, 03:07 PM   #4
Jester666
http://www.wikihow.com/Pick-a-Lock HTH a bit.
Old 20-01-09, 03:07 PM   #5
timwilky
timwilky's Avatar
is it the type that uses a eurocylinder insert. they are simple to remove/replace
Not Grumpy, opinionated.
Old 20-01-09, 03:07 PM   #6
Ed
A what?
Old 20-01-09, 03:08 PM   #7
Try a similar shaped key (if you can remember what it looked like)
Worked on our old garage when we lost both keys
Old 20-01-09, 03:09 PM   #8
Mr Speirs
Mr Speirs's Avatar
http://www.metacafe.com/watch/788366...for_beginners/
Old 20-01-09, 03:10 PM   #9
Filipe M.
Get a local chav to do it for a fiver?
*ducks*
Old 20-01-09, 03:19 PM   #10
tigersaw
tigersaw's Avatar
chisel out the wood on the inside, replace the mortice lock, replace the wood. Add sliding bolts top and bottom on the inside.
Hmm, might be cheaper to get a lockie, but you will probably still need a new mortice lock.
Picking up your bike maultin SV Talk, Tuning & Tweaking 13 15-01-08 06:07 PM
erm, not having tax on the bike you're picking up Kinvig Idle Banter 14 12-01-08 03:39 PM
More brain picking on the rubber orose Tyres 3 17-07-07 06:49 AM
ignition lock, seat lock, and key adam_castell For Sale - SV's and SV related items 0 27-02-07 07:56 PM
strawberry picking Quiff Wichard Idle Banter 10 05-07-06 12:43 AM
