Old 22-01-09, 01:33 PM   #1
Gazza77
Gazza77's Avatar
Default DVD-R/DVD+R - what's the difference
On a machine that can use either of the above, does one have an advantage over the other?
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 22-01-09, 01:46 PM   #2
ogden
ogden's Avatar
Default Re: DVD-R/DVD+R - what's the difference
DVD+R's slightly better at error avoidance and correction and you're a little more likely to be able to burn dual-layer, doubling the data capacity. DVD-R has been around longer so is more likely to work when you try and play it back in an older device.
Other than that, they're pretty much the same.
ogden
S1000XR | 990SMT | YZF-R6 #7
ogden is offline   Reply With Quote
Old 22-01-09, 01:46 PM   #3
SoulKiss
SoulKiss's Avatar
Nope - price *maybe* I seem to recall that once upon a time there was a price difference.
But basically same speeds, same capacity.
Old 22-01-09, 01:56 PM   #4
Baph
I could get all technical about the difference between + and -, but I think that's beyond the scope of the question.
SoulKiss' answer pretty much sums it up. There's no real difference in the technology. About the only problem you're likely to run into is any other devices you want to stick the disc(s) into, what do they support?
Old 22-01-09, 01:57 PM   #5
mike_avfc
from memory - wasn't it -r that was a panasonic only format and then all the other manufacturers used +R, i'm talking about DVD players only. in a similar way to the blu-ray / HD-DVD format.
all writers for PC's support both but i do believe that was the original thinking behind the differences between + and - It was definately something to do with a panasonic patent.
Old 22-01-09, 02:08 PM   #6
Baph
DVD-R was developed in 1997 by Panasonic, and yes, they held/hold the patent on it. However, most players supported it fairly early on.
DVD+R was developed later, 2002, and as touched on above, has better error correction capabilities (due largely to ADIP vs LPP).
That's without getting down to the nitty-gritty details of each specification.
Old 22-01-09, 02:09 PM   #7
Viney
-R's dont work on my DVD writer if that helps
Old 22-01-09, 02:11 PM   #8
startrek.steve
Price! DVD -R's are cheaper..
Old 22-01-09, 02:41 PM   #9
SoulKiss
SoulKiss's Avatar
I was trying to give an answer that was meaningful to the question
Yes of COURSE there is a difference
If that is too light on info try
http://en.wikipedia.org/wiki/DVD-R
and
http://en.wikipedia.org/wiki/DVD%2BR
Old 22-01-09, 02:44 PM   #10
ogden
ogden's Avatar
DVD-R was developed in 1977 by Panasonic
Are you quite sure about that?
ogden
Difference Between the R6 and the R6r????????? Mej Bikes - Talk & Issues 11 20-05-09 07:36 AM
Big difference in HP? KillaSV SV Talk, Tuning & Tweaking 5 06-04-08 07:36 PM
The difference between our needs. Jester666 Idle Banter 3 05-09-07 01:05 PM
Little mod big difference skulpt SV Talk, Tuning & Tweaking 16 14-10-06 02:44 PM
The difference between an R6 and the SV... Ibanez7779 SV Talk, Tuning & Tweaking 37 23-10-04 01:59 PM
