Old 30-01-09, 09:50 PM   #1
Dave20046
Dave20046's Avatar
Default SV Indicator flasher unit ?
Could someone please tell me how many pins the SV indie flasher unit has? And secondly where it is? I have the potential of having my bike ride able by the time the weekends through but I need to pick up one of these tomorrow and need to know how mnay pins it has.
Cheers!
Old 30-01-09, 11:48 PM   #2
Dave20046
Dave20046's Avatar
Default Re: SV Indicator flasher unit ???
doh
Old 02-02-09, 09:16 AM   #3
Dave20046
Dave20046's Avatar
Still none the wiser, I swear they've hidden it well on the sv
Old 03-02-09, 12:29 PM   #4
vardypeeps
Im not sure where it is located but it will have a plug with wires on that you will have to cut to replace it. I remember on my Bandit they put it on the sub frame behind the seat panels on the lhs. Maybe check there? If not someone metioned recent that there is a flasher unit next to the fuses?
It might be worth digging out the Haynes and checking in there to find it's location.
By the way when you do find it let me know!
Old 03-02-09, 12:43 PM   #5
Like I said yesterday it's under the seat next to the fusebox.
There are only 2 wires which need to be connected on the stock relay. A live feed and a flashing output (to the switch). So I would say a 2-pin relay.
Old 03-02-09, 12:45 PM   #6
vardypeeps
There you go. I knew it was somewhere lol
Old 05-02-09, 01:22 PM   #7
Stretch650
Hi Dave - if it is indeed a relay you need I have a brand new Motrax Flash-it unit that you can have! My SV was written off before i could fit it so its lying around at home! This was for LED indys on my K6 - not sure what you have !
PM me if you think it will help !!
LED indicators - which flasher unit? GOZA SV Talk, Tuning & Tweaking 0 15-03-09 09:27 PM
Flasher Unit adoh30 Bikes - Talk & Issues 0 05-08-08 06:10 PM
Where is the flasher unit?????? terryhopkins SV Talk, Tuning & Tweaking 7 18-03-08 05:10 PM
New Front Indicator Unit - Help Required. krhall SV Talk, Tuning & Tweaking 6 27-11-07 01:19 PM
Flasher unit. BURNER SV Talk, Tuning & Tweaking 2 24-01-05 07:45 PM
