Old 03-02-09, 10:37 PM   #1
stevo_sv
Default chain and spocket Q.
Just a quick 1 people,
The SV needs a new chain, so I'll be changing chain + both sprockets,
im planning on going +1 tooth to the rear sprocket, my Q. is will i be able to use the standard 110link chain? or do i need a 112link?
i.e with a new chain is there enough adjustment on the swingarm to get the wheel that little bit more forward to squeeze in that extra tooth?
thanks in advance
Old 04-02-09, 11:05 AM   #2
Dangerous Dave
Default Re: chain and spocket Q.
By adding one sprocket onto the rear of your SV650S will be reverting your bike to the same gearing as a SV650N.
Old 04-02-09, 11:09 AM   #3
Dave20046
Dave20046's Avatar
(I can never remember) what affect does this have? Better acceleration or better top end?
Old 04-02-09, 11:10 AM   #4
Dangerous Dave
Acceleration, but not much though.
Old 04-02-09, 11:26 AM   #5
stevo_sv
well actually im going +2, from a 44 to a 46.
and from an 108 to an 110 link if it will fit?.
but all these numbers will confuse the Q. lol
so on the basis of sv650n gearing, 15 - 45 - 110
will i get away with 15 - 46 - 110????
or will i need a 112 link chain dave?
Old 04-02-09, 12:18 PM   #6
On a curvy you'd be fine with 110.
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
46 Tooth Rear Spocket df1uk Stuff Wanted 0 27-02-09 01:35 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Chain & Spocket Life...? bobit69 SV Talk, Tuning & Tweaking 32 28-01-06 10:28 AM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
