Old 07-02-09, 03:53 PM   #1
williamturner1
Default Wanted: SV650 Front Wheel (2004,"pointy",Injected)
* EDIT * Front Wheel Sourced - NO LONGER REQUIRE ONE. Thank you. * EDIT *
Hi.
I would loooooove a front wheel for my baby.
I was subjected to an assassination attempt whilst on a roundabout, my jedi reactions saved me but the front wheel rim hit the concrete pavement and is now bent.
No guilt meant but she's off the road until I source one!
Pretty pretty please??
Silver Rim or Black Rim, Discs or no Discs, Im just after a wheel thingy.
Bike: SV650s k4, point/injected, 42k joyous and loved miles on the clock.
I will update this post right HERE if I no longer need one.
Regards Will Turner, william.turner AT imperial.ac.uk, 07951 555 867
Old 07-02-09, 04:09 PM   #2
phil24_7
Default Re: Wanted: SV650 Front Wheel (2004,"pointy",Injected)
How damaged is it?
Motoliner in Kent do a repair service which doesn't cost the earth.
Regards
Old 07-02-09, 05:08 PM   #3
williamturner1
Dammm .. good thinking batman!
I hadn't even considered a repair. I will look them up. Pls let me know of anyone else recommended.
The Damage:
I will post a photo up of it by 9pm tonight (saturday). The rim has buckled both outwards and inwards (towards the hub), as you would expect from riding directly at the 3inch high conrete kurb.
Only one side of the rim received the impact, the other side looks ok. The impact is bad but does not leak air. As you spin the wheel, it does shift 0..5cm-1cm sideways around the impact zone.
How damaged is it?
Regards
Old 07-02-09, 06:32 PM   #4
phil24_7
Sounds finer for a repair bud, send a pic to motoliner to get their opinion too.
Regards
Old 08-02-09, 12:10 AM   #5
Spikenipple
Spikenipple's Avatar
I had my front wheel repaired at Motoliner after hitting a huge rock in the road. Cost me £100 altogether. I doubt you'll find a second hand wheel for that little.
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 08-02-09, 08:04 PM   #6
williamturner1
Originals:
http://www.will-turner.co.uk/_Misc/IMG_0708sm.jpg
http://www.will-turner.co.uk/_Misc/IMG_0706sm.jpg
Comments welcome.
Old 08-02-09, 11:01 PM   #7
phil24_7
I would say that's fine for a repair but send the pics to motoliner and they'll let ya know for def.
Regards
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
WANTED front wheel for a pointy/03 onwards model sv650 sv650k4 Stuff Wanted 1 30-01-08 03:36 PM
Need help finding very flash "moving" custom wheel andy Bikes - Talk & Issues 34 01-12-06 04:53 PM
Front "Braker" or "Rear "Braker" &q BURNER Bikes - Talk & Issues 9 27-02-05 01:04 AM
