Old 09-02-09, 05:47 PM   #1
SV Meldrew
Unhappy Help - Front Caliper Mounting Bolts
I've just used my shiney brand new Norbar torque wrench and have overtightened the front brake caliper mounting bolts! I Don't know how this has happened as I set the torque to Haynes specifications?
Does anyone know what kind of re-thread would be best bearing in mind it's the brakes?
Old 09-02-09, 06:06 PM   #2
Default Re: Help - Front Caliper Mounting Bolts
Either your torque wrench is not calibrated, or the haynes spec is a dry torque and you have used copperslip.
Should be fine with a helicoil, but it is a fine pitch bolt IIRC. Have you got vernier and a thread gauge? (I can measure mine if you don't)
Old 09-02-09, 06:46 PM   #3
simesb
You've actually overtightend so much you've stripped the thread?
Old 09-02-09, 06:56 PM   #4
timwilky
timwilky's Avatar
My haynes
Front brake caliper mounting bolt = 39Nm. Hardly a thread stripping torque
Helicoil should be fine
Not Grumpy, opinionated.
Old 09-02-09, 06:59 PM   #5
Have you set it with lbf-ft instead?
Old 09-02-09, 07:08 PM   #6
SV Meldrew
Thanks everyone. I did use copperslip & thread lock. The wrench is twist n go nos. 1-9 (20nm-100nm). I just assumed the thread is b******d as I left it cold n wet with the hump. I will attempt to lever the bolt out tomorrow and check thread for certain.
Old 09-02-09, 07:10 PM   #7
timwilky
timwilky's Avatar
With luck it will be the bolt knackered, but sods law applies
Old 09-02-09, 07:10 PM   #8
What you use both for? One or the other.
Old 09-02-09, 07:27 PM   #9
SV Meldrew
1 side had copperslip on the other had thread lock.
Old 09-02-09, 07:30 PM   #10
Use threadlock on both, or copperslip and lockwire
Where can I buy caliper mounting bolts? Binky SV Talk, Tuning & Tweaking 4 07-08-08 10:46 AM
Front caliper bolts. Mark_h SV Talk, Tuning & Tweaking 4 13-03-08 02:00 PM
Brake caliper mounting points Philbo Bikes - Talk & Issues 5 19-07-07 05:22 PM
Rear brake caliper mounting bolt $tevo SV Talk, Tuning & Tweaking 12 06-05-06 07:29 AM
