Old 10-02-09, 11:18 AM   #1
Jay12329
Default Pointy clutch in a curvy?
Hi,
Just a quickie, is there any difference between the clutch in the curvy bikes compared with a pointy?
ta
J
Old 10-02-09, 12:40 PM   #2
jambo
jambo's Avatar
Default Re: Pointy clutch in a curvy?
Several differences in the clutch cover and gear shift mechanisms, but as far as I'm aware the actual clutch basket, clutch hub, and clutch steel and friction plates are interchangeable.
Best bet is to check the part numbers for both the donor and current bikes on a microfiche such as:
http://fiche.ronayers.com/
If the part numbers are the same you're in luck
Jambo
Pointy clutch cable simesb Stuff Wanted 0 11-04-09 03:16 PM
Curvy clutch FOO Stuff Wanted 17 20-09-08 10:25 AM
pointy Clutch outer/complet engine toadie Stuff Wanted 1 19-06-08 08:42 AM
clutch on k5 pointy sv650nutter149 SV Talk, Tuning & Tweaking 4 23-04-07 07:39 PM
Can a curvy clutch cover be replaced with a pointy one? UKStreetFighter SV Talk, Tuning & Tweaking 8 16-03-07 03:39 PM
