Old 10-02-09, 02:22 PM   #1
mikebrooman
Default Speedo malfunction
Hello all,
I've searched this and seems that mostly all the clocks go not just the speedo, but my speedo has gone and the rev counter is still working.
There is a light behind the speedo still, and initally it went, then came back and now has gone again (with in 2 days) so I suspect wiring?
What is the easiest way to get to the back of the clock to check for loose wires?
Oh, the odometer is working.
k2 curvy BTW.
Thanks
Old 10-02-09, 02:27 PM   #2
plowsie
Default Re: Speedo malfunction
I woulda suggested your speedo drive, but as you say, your odometer is working, but if you say your lights went, could be reg/rec. Get the fairing off and check for loose wires first.
Old 10-02-09, 02:28 PM   #3
husky03
Take front wheel off and check the drive there-you'll probably find that its been mashed
Old 10-02-09, 02:31 PM   #4
plowsie
Husk - odometer is still working...Mine is mashed and that doesn't work, obviously...
Old 10-02-09, 06:37 PM   #5
mikebrooman
Correction on this, the odometer is not working as an odometer, but it's working as in displaying figures, just not ticking up the miles as I ride.
Sry for any confusion.
Old 10-02-09, 06:43 PM   #6
captainsmelly
Mine's doing the exact same thing mate, started playing up after it hit the road. I'm interested to see how you fix it
Old 10-02-09, 06:43 PM   #7
flymo
flymo's Avatar
take a look at the speedo drive on the front wheel assembly. They always fall to bits. Common problem, you'll probably need to replace it.
Old 10-02-09, 07:16 PM   #8
plowsie
Speedo drive then if the odometer isn't ticking up. Take ya front wheel off and i bet some little black tabs will have fallen off
Old 10-02-09, 07:35 PM   #9
petevtwin650
Certainly would check the speedo drive first.
The four lugs get brittle I reckon with age and can snap off.
Close up of the four lugs.
Old 10-02-09, 07:41 PM   #10
plowsie
Pete, have you still got your old one?
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
how much is a speedo???? richie95 SV Talk, Tuning & Tweaking 4 09-03-08 06:59 PM
Speedo had a fit! Tris SV Talk, Tuning & Tweaking 1 26-03-07 11:33 AM
speedo....AGAIN! seandixie SV Talk, Tuning & Tweaking 11 01-03-06 02:48 PM
Speedo no go :( cuffy SV Talk, Tuning & Tweaking 2 11-12-05 10:34 PM
