Old 10-02-09, 10:35 PM   #1
s.j.robson@bt
Default Tyres
Hi
Can anyone help.....
I am thinking of changing the front tyre on my sv650.
It has the standard size tyre on it from new (the bike has only done 700 miles) and i would like to change it for something that looks and feels a bit more substantial !
Can anyone suggest a tyre size that will fit and a suitable tyre.
I still have the standard rear dunlop tyre on so would like if possible to keep to dunlop !
Also....any idea's as to where is the best value tyre supplier !
Many Thanks
Stephen
Old 10-02-09, 10:44 PM   #2
Dan
Default Re: Tyres
So you want to fit a bigger, heavier front tyre?
Why? Ever heard of unsprung mass?
Old 10-02-09, 10:46 PM   #3
fizzwheel
fizzwheel's Avatar
Default Re: Tyres
Personally I'd stick with the stock sizes. Nothing wrong with them IMHO. You could try a 120 / 70 on the front it'll change the handling though so make sure you know what you want and what you expect, it wont make the tyre look any wider though as the width is the same. I'm not sure what you're trying to achieve TBH.
Personally you've only ridden the bike 700 miles, then you havent done enough time on it, ride it more get used to it and the way it handles then think about making changes to it. Theres not alot wrong with the standard dunlops, certainly IMHO not enough to warrant throwing the front away with that little milleage on it. You'll want to fit another Dunlop to the front but I'm not going to recommend you one as I dont know what'll work with the rear Stock D220.
have a read of the tyre section for some more threads on this subject
http://forums.sv650.org/forumdisplay.php?f=138
Old 10-02-09, 10:46 PM   #4
s.j.robson@bt
Default Re: Tyres
OK fair point !
The standard tyre is not very confidence inspiring tho !!
What do you run with ?
Old 10-02-09, 10:47 PM   #5
sinbad
Default Re: Tyres
I don't think anyone will advise you to do that.
The wheel is designed to fit 120 section tyres and you'd struggle to fit anything much wider in there anyway. You wouldn't improve the handling even if you did, it would (I expect, no experience of it myself) feel heavier and steer slower. All in all not a great idea imo
There are those who think the Dunlops you're on don't inspire confidence, and there are tyres that look "chunkier" just because they have a different tread pattern. So consider swapping both tyres, (although I'd say the Dunlops are alright personally, it's not a night-and-day difference if you go for something better), but I wouldn't go for anything more extreme.
Old 10-02-09, 10:57 PM   #6
Default Re: Tyres
If you put a wider tyre on the standard wheel would it not then squish the tyre and make the shape more pointy rather than curved? So then you'd have less tread in contact in a straight line but more when it's cranked over? That's what I imagine would happen but god knows in reality
Old 10-02-09, 10:59 PM   #7
Default Re: Tyres
stick to the correct sizes, manufacturers must fit that size for a reason.
Old 10-02-09, 11:03 PM   #8
s.j.robson@bt
Default Re: Tyres
all sounds like good advice ! thanks !
the guy at the suzuki centre said the standard tyre was fitted for durability not grip !
Old 10-02-09, 11:06 PM   #9
fizzwheel
fizzwheel's Avatar
Default Re: Tyres
Thats probably because he was trying to sell you some new tyres
I mean no offence, but you've only ridden the bike 700 miles, ride it more, the D220 do give plenty of grip, just not as much as some other makes / types of tyres.
Is the SV your first bike ? If so ride it more, if you've been riding at this time of year its difficult to get feel from cold tyres, cold wet roads. You wont be the only one suffering from lack of feel / confidence. The grips there you just need to develop a better feel for it and you'll only do that by riding.
Old 10-02-09, 11:09 PM   #10
Default Re: Tyres
when i was choosing tyres for my sv my local fitter (x racer) said "you'll never push any of the modern tyres to there limits there all good just some feel different to others"
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Best Tyres Full Throttle Tyres 10 23-02-06 10:26 AM
New Tyres! Wonderful wonderful round new Tyres!! Kate Tyres 28 14-07-05 10:27 PM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
Tyres oh tiring tyres 454697819 SV Talk, Tuning & Tweaking 15 13-10-04 08:40 PM
