Old 12-02-09, 01:56 PM   #1
aermacchi
Default taper roller head bearings
Done a search, but cant find anything. Does anyone know either the sizes or bearing code nos for taper roller head bearings for a 99 naked sv?
Old 12-02-09, 01:58 PM   #2
Default Re: taper roller head bearings
Try marksman industrial supply
Tel: +44 (0)1252 345 455
IIRC they are about £17 for a set of koyos (one of best makes going)
Part no 22-1004 but I could be wrong on that!
Old 12-02-09, 02:20 PM   #3
aermacchi
I can probably get them cheaper than that through my work, but I need the actual bearing no. or sizes to check the catalogue
Old 12-02-09, 02:30 PM   #4
od id d
55 30 17 bottom
47 25 15mm top
Check these with someone else though as I'm not sure
Old 12-02-09, 02:47 PM   #5
Bottom is 32006 I think
Old 12-02-09, 03:00 PM   #6
aermacchi
Thanks for that, I've found the codes I need
Old 12-02-09, 03:03 PM   #7
What is code for top one? 32005?
Old 12-02-09, 08:20 PM   #8
mnrsmith
http://shop.marksman-ind.com/steerin...004-1297-p.asp
Old 13-02-09, 02:58 AM   #9
Oh cool, I got it right. I'm just as much of a sad f##ker as I suspected...
Old 13-02-09, 08:41 AM   #10
Dave20046
Dave20046's Avatar
Yeah I got koyos in mine. Didn't mean feck all to me (apart from maybe they were made in japan) but the guy that helped me fit 'em said they were good.
Head Race bearings Stu Bikes - Talk & Issues 4 13-11-08 01:14 PM
Help replace stem bearings with taper rollers zunkus SV Talk, Tuning & Tweaking 17 20-11-07 07:03 PM
Busted Head Bearings? Torn-Thorax SV Talk, Tuning & Tweaking 5 01-06-07 09:18 PM
Head stock bearings Davies SV Talk, Tuning & Tweaking 8 10-03-06 11:16 AM
Steering Head Bearings rjh SV Talk, Tuning & Tweaking 3 13-10-04 02:12 PM
