Old 17-02-09, 07:55 PM   #1
sv_rory
Default Sticking throttle
my throttle is sticking on my curvy, any ideas how to resolve
Old 17-02-09, 08:26 PM   #2
Default Re: Sticking throttle
In no particular order:
Cable adjustment, (too tight), cable routing, (bends too sharp), cable damage, (kinks, lack of lubrication), twistgrip sticking, twistgrip rubber fouling on bar end/throttle housing, carb/throttle body linkage/s sticking, carb/throttle body spindle/s sticking.
So, no, not really. But there's a few ideas.
Old 17-02-09, 09:44 PM   #3
sv_rory
how do i lubricate the cable and the throttle assembly?
Old 17-02-09, 10:58 PM   #4
MrG650
just had the same problem.mypost is about 4 down on page4
i started by disassembling the rhs switch gear,2 screws underneath.sprayed a bit wd down the tubes. This didnt solve it for me so followed the cables down to the carb behind the radiator.I found it easier to gain access to both carbs by lifting the tank and popping the air filter off to get to them.disconnected the cable then took the mechanism apart .cleaned ,greased and put back together. Took me about 2 hrs but that was just cos it was the first time id ever seen the carbs let alone took em apart.If ur a noob like me its Not as scary as you might think.Just take a pic of eveythin b4 u take them apart then u cant go wrong.
this sorted it for me hope it helps u.
Old 17-02-09, 11:41 PM   #5
sv_rory
Ah brilliant, i will give this a go in the morning then, do you have any pictures of the mechanism you took apart? what did you grease it up with wd ?
cheers
Old 18-02-09, 01:13 PM   #6
vardypeeps
No use grease instead of WD.
If you lift your tank and action your throttle you will see the pully moving on the right hand side of the carbs.
Gearchange sticking madeye SV Talk, Tuning & Tweaking 12 21-01-09 12:21 AM
I might be sticking around, so hello everybody mark grinyer Idle Banter 18 29-09-08 04:05 PM
Throttle / Revs sticking (and now brake question) goof SV Talk, Tuning & Tweaking 15 12-06-06 09:54 AM
Throttle sticking/stiffening KayDee SV Talk, Tuning & Tweaking 1 14-05-06 12:44 PM
Sticking reg/reg? northwind SV Talk, Tuning & Tweaking 16 29-01-06 11:25 AM
