Old 25-02-09, 09:46 PM   #1
Al_Sweetman
Default Brake Overhaul - picture heavy
OK,
As promised I'm uploading piccies of my brake overhall.
This is day one - showing (brief) pics of what it looks like before, finishing with the end-of-day-1 results...
Calipers before start
The spring is meant to be silver!
Pistons (one clean-ish)
Results after day one - lots of autosol, brake cleaner and hard work.
Getting there slowly!
Tomorrow brings sorting out the inside of the piston chamber, and fitting new seals etc.
Old 25-02-09, 09:48 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Brake Overhall - picture heavy
Any instructions? Or explanation on what you did matey? I need to clean mine up but wouldn't mind knowing the best course of action. Do the pistons just come out with no messing? And go back in straight forward enough? Have you felt an improvement?
(I intend to do it with them still on the bike)
Old 25-02-09, 09:55 PM   #3
Al_Sweetman
Will be coming along soon - writing down what I've done so far outside of t'internet... That way I won't lose it when my connection goes!
Quick responses:
> Any instructions?
Coming
All depends... mine didn't!! Had to get them most of the way out and then used thin bit of rubber (heatshrinking I think) to protect the pistons while I pulled the buggers out with some pliers.
That is the million dollar question I hope to find out by this weekend! Put it this way, when I took them apart, the pads weren't sliding at all, and at least one was seized...
Old 25-02-09, 10:29 PM   #4
Suzuki kindly provide a hydraulic brake piston removing tool on the bike as standard.
Old 25-02-09, 10:34 PM   #5
Richie
fantabulas
Richie's Avatar
Loving the glass of wine.... lol
clean pistons you have there...
My Flickr photos
Old 25-02-09, 11:19 PM   #6
pencil shavings
Old 25-02-09, 11:31 PM   #7
ThEGr33k
Ill probably have to do this at some point too Not that they feel bad, quite the opposite.
Old 26-02-09, 08:03 AM   #8
Dave20046
Dave20046's Avatar
That's fecking generous of them...unfortunately I didn't get the tool kit with my bike, previous owner lost it
Old 26-02-09, 11:31 AM   #9
breakz187
Default Re: Brake Overhaul - picture heavy
Pump them out with the brake lever!
Old 26-02-09, 11:35 AM   #10
Al_Sweetman
tee hee!
In principal, yes... but be warned (as I found to my detriment) it's more than likely that one piston will be all to happy to pop out, and will do so before the other one can, meaning that as you're pumping on the brake there's suddenly a pop and a squirt and all the brake fluid that was behind the (now extracted) piston goes everywhere, and you have to resort to pliers to remove the other half-in, half-out piston
Brake Overhaul Crash_Artist SV Talk, Tuning & Tweaking 3 18-02-09 07:44 PM
Bike Overhaul sv_rory SV Talk, Tuning & Tweaking 32 13-02-09 04:34 PM
Caliper overhaul. arcdef SV Talk, Tuning & Tweaking 114 31-01-09 04:57 PM
Front brake overhaul - how much? DarrenChay SV Talk, Tuning & Tweaking 7 03-01-09 09:12 PM
Brake overhaul Fuzz SV Talk, Tuning & Tweaking 4 13-03-06 11:51 AM
